Author Topic: Air drying in Reefer Container?  (Read 598 times)
Offline JasonRerras
« on: April 17, 2017, 01:57:18 pm »
Does anyone have any experience air drying in a Reefer container? Currently sawing a lot of 12/4 slabs, mostly different oaks, and a Cherry, and have them stacked outside, but I also have a 53' Reefer that I could put them in.  Obviously Sun and Wind exposure are eliminated.   Curious if this would be beneficial in any way?
MS880 60" CSM and stuff
Offline Farmerjw
  • I'm so far behind I think I am in first place.
Re: Air drying in Reefer Container?
« Reply #1 on: April 17, 2017, 02:17:17 pm »
Had a buddy with a sawmill until his divorce.  :o
Anyway, he had two reefer trailers set up with solar fans at the top of the walls of the trailer (two on each side, staggered).  Vents at the bottom of the two doors with sliding door to impede air flow.  Seemed like he was handling wood all the time, but it worked well for him.
Premier Bovine Scatologist
Offline Den Socling
  • just wondering
    • PC Specialties
« Reply #2 on: April 17, 2017, 03:58:54 pm »
That sounds like a good idea. It would basically be a predryer if the sun added a little heat during the day and the fans moved enough air and you had that sliding door to regulate airflow and you knew what air flow was in there and it was flowing evenly through out the load and and and......... ;)
Offline JasonRerras
« Reply #3 on: April 17, 2017, 05:22:54 pm »
Hahaha, yea, it could get complicated real quick!  Need to get a thermometer in there and see what the temperature cycles look like.  The idea right now is to air dry to EMC then go to a Solar or DH kiln.  I figure I have two+ years to come up with a plan or find some investors to buy a Vac Kiln  ;D
Offline Farmerjw
« Reply #4 on: April 21, 2017, 12:18:27 pm »
Yes, I forgot to add that he had painted them flat back and they were hot inside!
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #5 on: April 22, 2017, 06:42:57 pm »
Reefers function well as kilns but are not the easiest to load and unload.
1992 LT40HD
The winds of change are blowing at hurricane force and I don't like it but good shall come even though I see not how.
Offline Tree Dan
  • I may be In Canada but my heart Is also In the U.S
« Reply #6 on: April 22, 2017, 08:03:38 pm »
Cut the ends out of them and run a rail track through the box.
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
