recomendations for motor
Started by obcexp, April 11, 2017, 07:41:55 PM
obcexp
I picked up my 1991 LT30 this weekend and have taken off the 10HP electric motor. Going to go gas power what are my options and recommendations from you guys in the business?
Darrel
22 hp predator from harbor freight. Here's a link to a thread about installing said engine on a LT40.
https://forestryforum.com/board/index.php/topic,87965.0.html
1992 LT40HD
pineywoods
One you probably never heard of, but I can recommend is an industrial engine from kawasaki. 22 -27 hp V twin that's liquid cooled. Comes complete with cooling system. Weighs about the same as comparable air cooled. I have one on a 95 woodmizer lt40, love it..
killamplanes
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
sawguy21
You need at least 30 hp in gas to produce the torque equivalent to a 10 hp electric. That Kawi LC Pineywoods talks about is sweet but pricey. Briggs and Stratton has a 35 hp Vanguard V-twin that might meet your needs.
fishfighter
Is that electric motor 3 phase?
Chuck White
I replaced the 24hp Onan on my mill with a 25hp Kohler a couple of years back!
It was a very simple switch, only totaled a couple hours and we were done!
It was ordered from Wood-Mizer and included everything required!
FloridaMike
I have also been eyeing the LC Kawasaki's.  A google search found a 27hp (FD750D-S02) for $1721 delivered or a 31hp (#FD851D-S00) for $2300 delivered.  I feel that is a good price for a liquid cooled engine IMHO.
Mike
pineywoods
Them kawasaki's are industrial engines, lots of them on garden tractors, etc. Torquey beasts. Mine replaced an 18 hp briggs. I run 10 degree blades on everything, i can bogg the motor down but it ain't easy..
Bruno of NH
they run the Kawi motors in the stand up mowers at the condos i work at
they never have any problems with them
SineWave
Not that this is (probably) relevant, but I had a Kawi engine in a John Deere tractor/lawnmower, and parts weren't cheap. At one point I thought I might need a starter, and I think they wanted $300+ for a starter for a 14hp motor (and this was 15 years ago).
I replied, "How much for the entire engine?!?!"
muggs
So why did you take off the electric motor? Maybe so you can be portable.   Muggs
obcexp
Thanks guys, I did take off the 3phase electric not much available here. Is the 35hp Vanguard too heavy for a LT30?
obcexp
I looked at the Predator 22 hp its cheap enough. Do you guys with LT40s find the 22 to 24 hp enough power? Has anybody put the Kawasaki FD 851 31.0 HP on a LT30?
jmouton
i wouldnt go much over 100 pds, with the motor ,,  single chain and all,,,,,it has worked on our lt-25 and the chain is still good  and solid  ,25 hp is a good size the kohler i think has some good torque, we dont have any problems,
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
obcexp
I have the double chain on the set works WM tech said 200 lbs but that seems heavy to me.
