Author Topic: Shooting a fence line  (Read 2039 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Shooting a fence line
« Reply #20 on: April 11, 2017, 07:19:29 am »
I use a laser  at night.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline LeeB
« Reply #21 on: April 11, 2017, 07:52:30 am »
But, but, but....... There's MONSTERS out at night.  :D Don't know that I want to try traipsing 2 1/2 mile through the woods at night trying to mark out a fence line. Would be a good idea for open and flat terrain though.
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346, 372 and 562XP's. Stihl MS180 and MS361, 1998 and 2006 3/4 Ton and 2005 1 ton Dodge 5.9 Cummins 4x4's, 1989 Dodge D100 w/ 318, and a 1966 Chevy C60 w/ dump bed.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #22 on: April 11, 2017, 07:55:20 am »
   Monsters, smontsters... You've got the laser to protect yourself if old Sasquatch gets after you distract him like a big old housekitty. :D
(I will admit you probably have more dangerous snakes out there than in PA.)
Offline LeeB
« Reply #23 on: April 11, 2017, 08:19:57 am »
Obviously you sir have not watched the beef jerky commercials on tv.  :D
Offline LeeB
« Reply #24 on: April 11, 2017, 10:44:17 am »
There is a iOS app called Theodolite that might work. $6 should not impact the retirement fund too heavy. I shot a few lines witn it, and it worked well. It may meet your needs. There are a couple of similar free apps. I mounted my phone to a tripod.
There is a free Android app called Dioptra that claims to do the same.
Does this app require cell reception to work? May not do me any good if it does.
Offline Larry
« Reply #25 on: April 11, 2017, 11:01:11 am »
Putting a fence on the property line in Arkansas?  That's an interesting new concept.  Some Yankee musta thought up that idea. :D :D
Larry
Nine out of ten trees recommend wood for your building project.
Offline LeeB
« Reply #26 on: April 11, 2017, 11:08:01 am »
Guess yo're right Larry. What was I thinking? Just string it out and hope it's on my side or the real owner doesn't catch on. Not the way I operate.
Offline Larry
« Reply #27 on: April 11, 2017, 12:02:05 pm »
Just a teasing.  The fences on my property were all built by previous owners and none are on the property line.  One wanders off a 100 yards on the neighbors ground.  An California investment bank bought that property and wanted me to move the fence.  Since I don't need or want a fence I gave them the fence....they still weren't happy. :D
Larry
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #28 on: April 11, 2017, 12:02:45 pm »
That's what the past owner of a part of my land did. Seems her motto was if in doubt put the fence on the other guys land. In some areas she was 50+ feet over.
We bought our land at about the same time. She started fencing from day 1. One Sunday morning several of the local Menfolk came up to talk to the gol DanGed Yankee Florida Boy that was stringing fence on their land. They were NOT happy people. All were armed and not shy about me seeing that. Told me if I didn't stop I could get burned out and if I was lucky they'd maybe let me get out of the house first.
We got it worked out once they saw how nice of a guy I am. ;D
Kubota L-4200, Ford 8N, S-10 4WD Beater truck, Chainsaw, Bush Hog, couple ATV's and 141 acres of trees I'm not sure what to do with but I sure do have fun and enjoy being in the woods!
The First 50 years of childhood is always the hardest.
Offline petefrom bearswamp
  • Location: Finger Lakes region of NY, no more FL in winter
  • made 70-10 and still feelin pretty darned good!
« Reply #29 on: April 11, 2017, 07:58:30 pm »
A method used here in NY by the nysdec was as follows.
Bear in mind this was when i was young and now the litigious society may require more accurate results.
It was used to establish state land boundaries.
We worked in chains.
Say you have a line 10 chains long (660 feet)
Both corners have been set by a surveyor.
We used a staff compass and used the bearing given on the survey map.
Working on the compass bearing we set temporary posts every measured chain until 10 chains was reached.
This was usually fairly close to the corner.
We measured the distance to the corner at say 40 feet with no regard to the usually negligible angle..
this means that every chain or 1/10th of the distance is 40 divided by 10 so at every temporary post we measured the appropriate distance and set a more permanent marker.
The first one 4' then 8' then 12' and so on.
then the line was blazed and painted.
Pretty darned close.
Many miles of State land was delineated in this way.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline clearcut
« Reply #30 on: April 11, 2017, 08:57:59 pm »
The Theodolite app uses the phone's camera to view in the distance, and the screen as a display. You line up crosshairs up and down and left and right on the objective. The phone's GPS gives the bearing.
It's easier with 2 people, one to sight and the other to hold a sighting rod. I used a piece of PVC with electrical tape wrapped around.
The website for the app is:
     http://hrtapps.com/theodolite/
Regarding a cell connection, from the developer:
Quote
Does Theodolite work without access to the internet?
Most of Theodolite's features will work without access to the internet, except for online maps, e-mail export, and location services for wifi-only devices (wifi-only devices are iPads and iPods lacking GPS hardware and 3G/4G cellular hardware). iPhones and iPads with GPS hardware can get location data without an internet connection, however it will take longer for the on-board GPS hardware to function in a standalone mode without help from internet databases to speed refinement.
When using a GPS-enabled iOS device without an internet connection, allow extra time (tens of seconds, or a minute) for the device to acquire an initial position fix. Once the initial position is locked in, subsequent position updates will behave normally.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #31 on: April 11, 2017, 09:13:22 pm »
Quote
I'd be interested to see how well that App performs by locating the new set points with survey grade instrumentation and making the comps.
D
Offline SwampDonkey
  • Large Tooth
« Reply #32 on: June 09, 2017, 10:36:51 am »
Recently, I've used Mapwel to build my own custom map from provincial property maps (data is Shapefile format). Then load the maps onto my Garmin GPSMap64S. I only loaded up a couple counties where I'm working. Shows lines and property ID numbers. From the ID numbers you can look up ownership and tax levy and so on if you want from the provincial government web. Must be something similar in most states, maybe not all.
The layer looks something like this when loaded into the GPS. There are a couple files that make it up, one has the ID's in a polygon and one the lines. The GPS can't distinguish polygon edges when all loaded together (no outlines), so need the lines layer on top.
Dirty Harry
Offline LeeB
« Reply #33 on: June 09, 2017, 12:03:07 pm »
I ended up get the pros to come out and do it. $4200.
Offline SwampDonkey
  • Large Tooth
« Reply #34 on: June 09, 2017, 04:57:39 pm »
That's a lot for running woods lines. Did 450 acres here on one parcel in 2001 for $750. Surveyor and his axe man. Not even forest companies would pay those rates.
Dirty Harry
Offline LeeB
« Reply #35 on: June 09, 2017, 09:11:59 pm »
It is what it is. The other bid was almost $7000.
Offline dgdrls
« Reply #36 on: June 10, 2017, 10:16:02 pm »
As I recall the fee included blaze, flag and file a new plat,
Pretty cheap IMHO for securing the boundary, having a plat prepared and filed with the County
and knowing if there is a challenge the surveyor has stamped the Plat
is responsible for it and will defend it if needed.
If you consider the 450 Ac work on a cost per LF basis and compute it as a box (round numbers), $750/17710LF that person worked for $0.04LF and paid his Ax man.
Compute inflation to 2016 and you would be in the $1050 range,  $1050/17710LF $0.06LF.
I don't think anyone here on the FF would work for that rate.
LeeB keep those lines cleared, brushed and freshened-up annually, the
work and the plat are an investment in the land.
Best
D
Offline LeeB
« Reply #37 on: June 11, 2017, 02:00:59 am »
A big part of the decision to go with a professional instead of doing it myself.
Offline SwampDonkey
  • Large Tooth
« Reply #38 on: June 11, 2017, 04:56:29 am »
The field work was only 6 hours, the line trees were blazed and flagged and line brushed. It was before leaf out to and not much undergrowth, clear sailing more or less. I went around with the paint and brush myself after. There won't be any challenge to the lines he run or to the paperwork registered. We have a surveyors act and we also have quieting of titles act here. Base was set up in the field and a rover GPS used on the lines.
So once the following is satisfied she's a done deal.
1(5)The application shall be supported by the following particulars which shall be filed with the Notice of Application:
(a)the title deeds and other documentary evidence of title, if any, in the possession or under the control of the applicant;
(b)an abstract of title, together with a concise statement of the facts relied on by the applicant to make out the title and which do not appear by such abstract, certified by a solicitor of The Court of Queen’s Bench of New Brunswick;
(b.1)a plan and a description of the land prepared by, and verified by the affidavit of, a land surveyor registered under the New Brunswick Land Surveyors Act, 1986 who has personally inspected the land, unless the judge dispenses with them for special reason;
(c)an affidavit in accordance with section 2 by the applicant or other person or persons, unless the judge for special reason dispenses therewith;
(d)a schedule of the particulars produced under this subsection.
Same surveyor we used works on land owned by the local mill. I think he works for them 3 days a week keeping the lines updated.
Defending a survey would be extremely rare up here. Not to say that someone doesn't come along and says it's wrong, which could be an adjacent owner. But if he ain't a surveyor it won't get him far. The Surveyor's Act comes into play. And if he defaces the established line he might be getting a few free meals or very expensive ones. A surveyor is suppose to be non biased, much like a scaler of logs. I can use a licensed scaler from your mill with no bias, if he intends to scale for long. He doesn't have to scale my logs, but if he does and cheats me willingly, there are consequences. (NB Scaler's Act) ;)
Dirty Harry
Offline LeeB
« Reply #39 on: June 11, 2017, 07:03:33 am »
I wish it was that cheap in my area. Believe me, I didn't want to have to turn over that much cash.  :-\
