Getting some logs, need help i.d.`ing
Started by alanh, April 05, 2017, 04:37:27 PM
alanh
have been given a few loads of logs, the ones in the truck I`m told are pine, I still have a hard time I.d ing between pine and hemlock, one of the butts looked like it had shake from what Ive read here. I don`t know what the hardwoods on the ground are...
Thoselook like eartern white pine to me.
hemlock don't have pitch that runs like that.
Kbeitz
Yep... Pine will have a lot of sticky pitch that gets on everything.
Also the Pine bark on the small limbs is smooth.
Love machine shop work
and Wood work shop work
And now a saw mill work
Don P
On the ground I believe you have a northern red oak, looks like a nice stick.
Ron Wenrich
My first thoughts of the log on the ground was pin oak.  I know species look a lot different in different areas.  A log that size in my area in red oak would have deeper fissures.  Tight ones like that are often pin oak.
jmouton
i am having the same problem,  except we have 65 logs to i d ,,  most of them dont have bark on them ,,  ill do the smell test ,  cut  end with chainsaw test ,,  and the sawmill test ,,,so hopefully we get them all right ,,
        jim
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
The first pic is definitely in the red oak group.
warina drive
If you can check the leafs......pine are long and round,hemlock are short and flat.
Nice logs anyway
69bronco
Deese
Yes definitely red oak (pin oak is in red oak group). Erythrobalanus
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
alanh
