JD 540A
Started by NWP, April 04, 2017, 05:17:49 PM
NWP
I'm working on an old 540A. Are they 12 or 24 volt?  The batteries are set up in 24 volt configuration but the alternator was a 12 volt. Alternator isn't working right now so I'm trying to figure out if I need to hook the batteries up as 12 or get a 24 volt alternator.
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
Maine logger88
OH logger
12 volt. they are hooks in series I think its called.
john
henry co.
Mine 540a is 12 volt
NWP
Ok. I'm guessing they didn't know what they're doing when they hooked up the batteries. And in turn it fried the alternator
coxy
that thing should spin over like there is no pistons in it at 24v  :) did you have it running if not  does it have that electric shut off in the injector pump it may have fried that if it doesn't start
Maine logger88
If it runs it didn't fry it on a Deere it needs power to run. I sometimes wish they were more like a cat tho
NWP
It did spin over good. Yes, I had it running and pulled wood for a couple of days.
