BRUTE FORCE Authorized Dealer
Author Topic: Black Locust ID help  (Read 1989 times)
Offline runmca
« on: April 04, 2017, 10:50:42 am »
Hi-
First post, longtime reader. Such a great forum- kudos to the founder, administrators, members and sponsors!
So here goes, I need some help identifying Black Locust. I'm a novice at distinguishing wood species, so any help would be appreciated. Here's a picture of the wood in question.
Thank you,
2017 Peterson JP swingblade mill
Offline Ox
  • Trying to learn/remember something new every day.
Re: Black Locust ID help
« Reply #1 on: April 04, 2017, 01:01:06 pm »
That looks more like honey locust to me.  If it is, it's less rot resistant than black locust.
Offline low_48
« Reply #2 on: April 04, 2017, 09:16:44 pm »
I'd say osage. Black locust has a green tint, honey locust is salmon colored, osage is yellow.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: April 04, 2017, 09:25:21 pm »
Sure looks like black locust to me.  Black locust has a very interesting characteristic.  It only has one to two annual rings of sapwood.  Very unusual.  The log in the pic only has one or two annual rings of sapwood.
Down here, honeylocust bark is more smooth or breaks into plates.  Black locust bark is furrowed with distinct interconnecting ridges.  In the pic, the bark looks more furrowed and ridged, not platy.
Offline Magicman
  • A "Traveling Man"
« Reply #4 on: April 04, 2017, 09:31:23 pm »
If it was growing on my property it absolutely would be Black Locust.
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline Ox
« Reply #5 on: April 04, 2017, 09:33:10 pm »
I guessed honey locust cause my honey locust here is not as deeply furrowed as my black locust and looks remarkably like the photo.  My black locust is easily twice as deeply furrowed as what's in the pics above and is yellowish when freshly cut!  This might be a location thing going on here...
There's a black light test which will glow if black locust.  Not sure about the others.
Offline runmca
« Reply #6 on: April 05, 2017, 07:56:46 am »
Thanks everyone. I haven't seen this wood in person yet, and this info will be helpful.
Offline WDH
  • Forester
« Reply #7 on: April 05, 2017, 08:09:18 am »
Most times, honeylocust has thorns growing out of the trunk and branches.  These thorns are modified branches, and are 3" to 6" long and dangerous, and they branch out themselves with branch thorns like a twig on a tree.  On the other hand, black locust thorns are modified stipules, and only occur in pairs at the base of the leaf stem (rachis in a compound leaf like black locust).  These stipular thorns are exactly like the pair of thorns on a rose bush.  They are always in pairs at the base of the leaf stem, never branched, small at about 1/4" to 1/2" long, and never on the trunk.  If you have a twig, you can make a definitive diagnosis.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #8 on: April 05, 2017, 10:27:31 am »
How long have they been cut?
Not Honey locust for sure, at least not how they look here.
I initially leaned Black Locust, but couldn't rule out aged Hedge, so I didn't comment.  Would be rare to get a stack of straight Hedge though.  I have been fooled by barkless Mulberry, but it sure doesn't look like Mulberry bark around here.  Still leaning Black Locust.
Like WDH said, if you could get a twig or even fresh cut, that would help.
Ox, blacklight test is interesting!  Will have to try that!
Lucas 6-13+slabber, Mr. Sawmill bandmill, orange chainsaws, JD SSL, Case Backhoe, farm tractors, trailers, and 150ish acres of trees.  Fledgling woodshop with CNC router, laser engraver, Woodmaster 712, and a Berlin 108 moulder (project).  Oh, and a lovely (patient) wife and four offbearers.
Offline Al_Smith
« Reply #9 on: April 05, 2017, 04:29:02 pm »
Mulberry is yellow and a second cousin to osage orange.Black locust seldom gets over two feet in diameter ,Honey locust can get huge,fat like an oak .Thorns that look like elk antlers .Be careful they can put your eye out and puncture a tractor tire .
Offline runmca
« Reply #10 on: April 05, 2017, 08:38:59 pm »
Not sure when they were cut. I do know they are between 6-12" diameter.
Offline ToddsPoint
  • Stockmaker and Carver
« Reply #11 on: April 06, 2017, 06:11:15 am »
I had never cut a black locust but read where it is rot resistant in contact with soil for 75 yrs.  I asked a farmer neighbor if I could cut one of his black locusts.  I told him I wanted to test the 75 yr. claim on a fence post or two.  He laughed and said I could have a tree but I better leave a note for someone on the 75 yr. thing.  I cut a tree and have two 8' logs to mill for posts. Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
Offline Don P
    • Calculator Index
« Reply #12 on: April 06, 2017, 07:18:07 am »
 :D
Like most naturally decay resistant species the results are highly variable. The trees don't read the textbooks. I've had locust fenceposts last 7 years and should probably leave a note on others.
Offline Magicman
  • A "Traveling Man"
« Reply #13 on: April 07, 2017, 09:59:10 pm »
We never used fresh felled Black Locust for fence posts.  They had to be bucked and stacked for a year before use.  Sawing fence posts was my Winter job for many years, and we used a 6' crosscut saw.
Offline Larry
« Reply #14 on: April 07, 2017, 10:44:07 pm »
I'm absolutely positive that's Black Locust because I can tell by its smell. ;D  Makes me hungry.
Don't waste any as its a fine wood for projects and I have made a few.  With exposure to UV it takes on a rich reddish hue.  The bench was fresh and had yet to turn color.
Nine out of ten trees recommend wood for your building project.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #15 on: April 22, 2017, 09:11:54 am »
  The end cut sure looks like our black locust here.
Larry,
   I assume you mean it smells like raw peanuts. That is what our fresh cut black locust always reminds me of.
Offline derhntr
  • Sawing lumber is addicting
« Reply #16 on: May 12, 2017, 01:03:19 pm »
I would have guessed Sassafras. The growth rings look a lot like what just got cut out of our fence line.
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
Offline Brad_bb
    • My timberframe blog
« Reply #17 on: May 18, 2017, 08:36:26 am »
It's not honey locust, not Osage, not Mulberry.  Could be Black Locust.  Not certain without hands on inspection.  Black locust has furrowed bark and around my parts, doesn't seem to get much bigger than 10 inches it seems.  Where are you/the wood located?
Offline WDH
  • Forester
« Reply #18 on: May 18, 2017, 10:34:08 am »
The pores of black locust and osage orange are filled with tyloses.  Not so in honeylocust and mulberry.  Osage and black locust have latewood pores that can band together in little strings, sometimes in a wavy pattern.  However, black locust only ever has one or two annual rings of sapwood.  Osage usually has more annual rings of sapwood.
Offline Babylon519
  • Circle Sawyer
« Reply #19 on: May 18, 2017, 12:55:24 pm »
A tree that I've been calling Black Locust fell this past winter. When it came down, it landed in a pond and I pulled it out a month ago. I found it was starting to sprout branches, so I took a couple pictures of it to show the forum. I don't see any evidence of thorns as described above. Is it really a Black Locust?
Cheers,
Jason
Jason
1960 IH B-275 - same vintage as me!
1960 Circle Sawmill 42"
Stihl MS440 & a half-dozen other saws...
