Solar kiln thermometer/hygrometer
Started by WLC, April 03, 2017, 04:38:00 PM
WLC
For those of you using a solar kiln what type thermometer/hygrometer do you use to monitor the temp and humidity in the kiln?  thanks!
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
losttheplot
you can get them from e bay for less than 5 bucks.
they have about 6ft leads and are meant for terrariums
DON'T BELIEVE EVERYTHING YOU THINK !
GeneWengert-WoodDoc
With the Virginia Tech design and similar, you do not need to monitor temperature to do a good drying job.  Of more importance is the daily drying rate of the wood...% MC loss per day...especially when above 40% MC.  As moisture meters do not work well above 30% MC, you need to use the weighing method, which is covered in most drying texts.
YellowHammer
Wall mart or any outdoor weather monitor, $20 bucks or so, with the wireless remote probe with temperature and RH.  It's good practice to know what the environmental conditions are to get the intuitive feel and understanding of drying.  Keep an EMC chart handy, and you'll know what conditions your wood is experiencing.
Not as exciting as TV, but more educational.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
