Author Topic: Kohler Engine is a Nightmare  (Read 7904 times)
Offline richhiway
  • Rich
Re: Kohler Engine is a Nightmare
« Reply #20 on: April 02, 2017, 03:16:45 pm »
Just a general suggestion. If you have recurring electrical or sensor failures double check and clean all your grounds. It is a good idea to include this in your maintenance schedule. Always use a "star washer" that will take a good bite. Also always keep a battery that is in good condition. If the alternator is constantly trying to charge a weak battery it will cause voltage spikes in the system. Be careful about jump starting for the same reason. This goes for all your vehicles and equipment,including late model diesels. Before you unhook the cables after a jump,turn on your headlamps so a voltage jump has somewhere to go.
Vehicle electronics are ultra reliable if you think of the amount of them out there running trouble free. A lot of problems are caused by bad connections and corrosion and are misdiagnosed. E.C.M. have been on cars since the 1970's.
Logosol M-7
New Holland 35 hp tractor
International T-6 Dozer
Takeuchi mini excavator
Stihl Chainsaws
Offline red
  • we will never forget
« Reply #21 on: April 02, 2017, 04:31:35 pm »
Gremlins
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline ladylake
« Reply #22 on: April 02, 2017, 04:57:01 pm »
  Good post above, with the high amp electric pumps and maybe a bad ground a voltage spike could fry  some electrical components.  Steve
Offline POSTONLT40HD
  • G29
« Reply #23 on: April 02, 2017, 05:45:59 pm »
If the grounds were not right or the battery or the alternator weren't right, it would show up on the laptop via the software.
As of now and the same as before, its idling and sawing wide slabs like a brand new engine.
No fault codes are coming up and she's just as smooth as silk when working.
No bad grounds.
I'm hoping the TPS was just a bad part. Kohler is making it right and not charging for another TPS.
We'll see.
I'm thinking......
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #24 on: April 02, 2017, 06:33:47 pm »
What I always wonder, is if there is any lower grade ethanol still in the line before I pump it.  Most gas stations around here that sell high test ethanol free have 3 grades pumping through one line.  So if the guy in head of you pumped 87 ethanol full fuel, is there still some residing in the line that will mix in with your non-ethanol requirements.  What I've done before to remedy this is I'd empty 1 gal first into my pickup, and then fill my gas jugs, but I don't have a gas eating pickup anymore so now I just prime the line onto the ground or into the garbage can before I fill up my fuel can.
(ok I'm just kidding about priming it onto the ground or into a garbage can. I just don't worry about it anymore, but I had thought about that lol)
According to the American Petroleum Institute the gas-pump hose typically retains about one third of a gallon of fuel.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline drobertson
« Reply #25 on: April 02, 2017, 08:03:39 pm »
I still believe its epa related and faulty designs that are suppose to make clean exhaust,  fact is it should not be happening, this fuel, smuele talk wears me out, they know fuel, just not the engineering to accommodate to meet epa specs worth any consistent performance. JMO,
Offline Delawhere Jack
  • I ought to know better.....
« Reply #26 on: April 02, 2017, 09:38:02 pm »
"SOFTWARE? WE DON'T NEED NO STINKIN' SOFTWARE!!"
The crank on the Onan goes round and round
Round and round!
Round and round!
 :D
black walnut, cherry, SYP, southern magnolia, poplar, hemlock, osage orange, red oak, white oak, chestnut oak, black locust, english walnut, ERC, WP, hickory, ash, black birch, beech, honey locust, apple, white cedar, black oak, basswood(?), sassafras and a "Christmas tree" full of iron
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #27 on: April 03, 2017, 12:45:12 am »
On the ethanol in gas issue, in Canada the law requires all Premium gasoline to be ethanol-free. That's specifically aimed at those of us who have engines that don't tolerate ethanol.
Last summer, after much soul-searching, Barb traded in her diesel Smart car. Our dealer/mechanic made it very clear that we could not use gas containing ethanol in the new wheels. After a month or so of driving, the "check engine" light came on, so Barb took it in for a look-see. The code came up as "ethanol in fuel". Well, we only used Premium (only two fill ups) so we couldn't figure out how it could happen ???. As it turns out, the sensor in the car will detect any amount of ethanol, even a trace ::).
Nearly all the stations around here use blender-type pumps -- one storage tank of regular fuel, one of premium fuel, push a button to get the mix you want and it comes out a common hose. So yes, even the small residue left in the hose will mix a bit of ethanol into the premium you put in your tank. No harm to Barb's vehicle, but she'd have to keep having the fault memory on the computer reset.
The dealer directed us to Chevron. Their pumps have three hoses -- one for diesel, one for blended fuel (including premium), and a third one for "premium plus" (which I suspect is just premium that goes through a dedicated hose). Naturally it costs more >:(.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline starmac
« Reply #28 on: April 03, 2017, 07:58:41 am »
Brucer, can I ask what kind of Auto that is??
Offline Clover
  • I'm newish
« Reply #29 on: April 03, 2017, 08:07:57 am »
In this day and age of ethanol free fuel about as common as leaded fuel what car manufacturer would make a car that won't use ethanol?
Home made 30 hp sawmill all hydraulic, stihl 026, 170, pioneer 65, John Deere 955 with home made forks. And a whole slew of other tools
Offline richhiway
  • Rich
« Reply #30 on: April 03, 2017, 01:48:56 pm »
I wasn't doubting that your tbs was your trouble,I was just giving some general info because folks where questioning the need for computers.
Trust me they are here to stay and will only get more complicated. I was trying to say that giving the amount of vehicle and equipment hours in use they have been proven extremely reliable,provide fuel efficiency,clean emissions and way more power and driveability. I love the old stuff too,in reality the new stuff is better in almost every area.
It reminds me of my old 1987 4cyl mercruiser. It had a delco points distributor and I don't know how many times it would not start until I cleaned the points. After sitting around they would get a little film on them.
I replaced them with a electronic ignition conversion and not only has it started instantly and been trouble free for the last 10 years, it runs better too.
Just don't forget the basics before diving in and replacing expensive components.
Logosol M-7
Stihl Chainsaws
Offline Brucer
« Reply #31 on: April 03, 2017, 11:03:18 pm »
I ain't sayin' :-[.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #32 on: April 04, 2017, 12:50:40 pm »
You realize that now ya gotta say or you'll never hear the end of it!  ;)
Offline scully
  • Orange Mills Matter
« Reply #33 on: April 06, 2017, 06:10:48 pm »
I have no general insite to this issue other than this . Last summer I bought a new 325 Miller Trailblazer I was sure I mentioned that I wanted the EFI . Koler . I took it back to the dealers shop a few weeks ago because I wanted them to check some settings for me . In conversation I mentioned something about liking the EFI engine on  my machine . The service mechanic looked at me and said yours is not an EFI engine . I started to get kinda mad untill he told me I have the better engine . From what he says they have had a bunch of problems with them . Now as for the red neck side of me I wish they would come up with a 4 cylinder gas for the lt40 series soon .
A mans greatest tools are his heart ,hands and his imagination .
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
« Reply #34 on: April 08, 2017, 12:00:36 pm »
I have a new lt 40 hyd. I up graded to 35hp Kohler. My problem is even after engine is warm I have to choke it to start. It is mounted at the very top of the engine , which makes it impossible to reach if head is in the  '' Raised  Position''. I have to lower to reach. I suggested to WM to put a solenoid on the cable with a toggle switch to activate choke. I know this is different than your issues, but  it felt like a good place to add my 2 cents.
  • G29
« Reply #35 on: April 08, 2017, 04:06:47 pm »
Is your engine an EFI?  say_what
I'm thinking......
Offline gmmills
« Reply #36 on: April 08, 2017, 11:57:17 pm »
  Woodweasel,
     I will bet that when you turn the key to the stop position the engine does not immediately stop running, it runs for a few seconds after the key is turned off. WM has this engine, G35, wired to shut down by de-energizing the fuel shut off solenoid at the bottom of the carb float bowl. This basically kills the engine by shutting off fuel flow, runs it out of gas. This is why the engine has to be choked to start even if it is warm. Most all other small gas engines are shut down,stopped, by killing power to the ignition coils. Cannot understand why WM does not wire this engine to shut down by cutting power to the ignition coils. It would only take another wire in the harness to achieve this.
     The engine in general is a real torque monster for being a high speed, air cooled, gas engine in it's horsepower range. Extremely impressive.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline ljohnsaw
« Reply #37 on: April 09, 2017, 12:15:34 am »
  Woodweasel,
Actually, this is a pretty good idea.  You don't have to worry about there being any old fuel gumming up the carb if it sits over the winter.  However, it would be nice to have the option to cut the fuel remotely.  You could rewire it...
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #38 on: April 09, 2017, 07:02:21 am »
Will all that's going on with the Kohler engine postonlt40hd, I want to thank you.
For letting me know not to buy anything with a junk Kohler on it .  ;)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #39 on: April 09, 2017, 08:27:16 am »
David, it seems that the model you and I have is the largest horizontal EFI engine Kohler makes.  I wonder why this is?
