2002 7.3 powerstroke oil leak, need advice please.
Started by fishpharmer, March 29, 2017, 08:48:09 AM
fishpharmer
I am changing the water pump and a few other things on my 7.3 powerstroke diesel.  (Ford F350).    I noticed this small oil leak.  Nothing dripped on the ground.  It appears to be coming from the either the front engine cover corner.  Or its coming from what I think are the freeze plugs (plugs with square inset).
While it apart I'd rather repair the problem.  Any one seen this kind of leak before, know an easy fix?  Any comments or advice are appreciated.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
moosehunter
Imo, those are not leaks. It's wet. Leave it be . You are going to spend a lot of time and money with almost no gain. If it was dripping then yes I would fix it.
Higher than my expectations
Ox
Agreed.  It's only a small, slow seep.  Not dripping, leave it be.  :)
One of the only seeps I might consider fixing is on a main seal but then I would try a seal conditioner first.
fishpharmer
Moosehunter and ox, I appreciate your input.  After I posted, the thought occured to me that a few cold nights in the teens may have shrunk metal/seals allowing the seep.  Maybe running temps will stop the seep.  Thank you!!
POSTON WIDEHEAD
coxy
you want to see a drip you should see my 7.3 if its cold it will push about a gal of oil out of the oil cooler the hotter it gets the less it drips after it gets to tep it stops  :D I think every gasket on mine leaks now with almost 500k I think its allowable  like others said if it ant broke don't fix it or you could be like the government and fix it till its broke  :)
fishpharmer
Quote from: POSTONLT40HD on March 29, 2017, 07:26:24 PM
Do you drive that truck a lot?
Not in several months.  A 3 way ball went thru my front end :'(
fishpharmer
Quote from: coxy on March 29, 2017, 10:27:12 PM
Thanks Coxy, I am going with "let it be."
coxy
snowstorm
up this way its good to have a few oil leaks if you dont the oil pan will rust out.
Ox
coxy
mine is all most rust proof with all the jb weld on it  ;D
Gary_C
I've had mine in the shop many times for oil leaks. Chances are your valve cover is rusting thru. Next will be the oil pan. I had to put a new valve cover on and a ton of JB weld on the oil pan cause it would cost so much to replace it.
Larry
Quote from: fishpharmer on March 29, 2017, 08:48:09 AM
There are plugs like those in the end of each head.  They plug the high pressure oil galley.  I had one leaking so I bought a new plug, less than $20.  Couldn't get the old one out so took it in to Ford.  They changed the plug and I asked how they got the old one out.  The mechanic said with a breaker bar using a 6' cheater pipe.  Said that is common....sometimes they can't get the plug out and have to pull the head.
Think I got another one leaking now.  Two bread pans on the garage floor take care of it.
POSTON WIDEHEAD
Ox
Raider Bill
Quote from: Ox on March 31, 2017, 09:59:13 AM
like an old harley marking its territory :D
Old Harley leaking oil were part of the design. When the leak stops it's time to add oil.
fishpharmer
Thanks for the comments.  The rust is minimal, never seen salty roads and very little time near any ocean.
