Author Topic: Taking Delivery  (Read 27127 times)
Offline Magicman
  • A "Traveling Man"
Re: Taking Delivery
« Reply #600 on: August 07, 2017, 04:50:58 PM »
 :o  Did everyone at the Pig Roast use the PortaJohn??   ::)
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
Re: Taking Delivery
« Reply #601 on: August 07, 2017, 07:00:20 PM »
That sure is what it looks like.
Offline grouch
  • I'm recyclable!
Re: Taking Delivery
« Reply #602 on: August 07, 2017, 07:01:29 PM »
Just about choked on supper when I finally figured out why you posted that here!
 :D
Find something to do that interests you.
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
Re: Taking Delivery
« Reply #603 on: August 08, 2017, 05:22:22 PM »
Jeff, Thats some messy looking "CRAP" !!!!!, I had a issue with the Stewart heating now that I have a temp gauge in it. I pulled the thermostat, some brain surgeon once upon a time put a new thermostat in with the linen parts tag still attached !!!!! the string was there but just gobs of linen fabric around the thermostat and filled the bypass tube. You never know !!!!!
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Taking Delivery
« Reply #604 on: August 08, 2017, 05:34:05 PM »
It's better, but not right. Looks to me like near a third of the radiator tubes have been soldered. I
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Taking Delivery
« Reply #605 on: August 09, 2017, 10:10:43 PM »
Looks like the radiator is the main culprit. I hauled it in today, it's only letting about 15% through. Zero water column. It has to be recored.
This is what a water distribution tube looks like. This is the extra engine that came with the truck, which turns out to have a bad freeze crack in the block. The distribution tube is great if I need it.
Offline grouch
  • I'm recyclable!
Re: Taking Delivery
« Reply #606 on: August 10, 2017, 12:57:09 AM »
There are people who can weld or braze a cracked block, so I wouldn't count that spare engine as scrap.
I had a '39 Ford 9N tractor that had a chunk put back in the block. It had a combination of brazing and nickel welding holding things together. The Shaker who sold it to me pointed it out first thing. Never had a problem with that.
Offline loggah
Re: Taking Delivery
« Reply #607 on: August 10, 2017, 07:08:23 PM »
Jeff, Sounds like your on the right track, mr truck will be happy when you keep its temperature down. Don
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
I had a dream...
« Reply #608 on: August 11, 2017, 10:36:47 AM »
So, I had a dream night before laast that caused me to stop anything else I was doing on M.R. Truck and address what happened in the dream.  I dreamed that one of the little neighbor girls had climbed up in the truck, which they do, because they like the truck. As I was watching, the little head disappeared below the windshield. That's when I heard the engine turn over and saw the truck lurch forward suddenly because she had scooted down in the seat and pushed the start peddle and the truck was in gear.
I have dreams like that all the time about things I never think of while I am awake. In this case, I woke up knowing I had a safety issue.  The starter peddle is wired directly to the starter. There is no neutral safely switch on this truck and shutting the key off only prevents the truck from starting, not from turning over.
So, after short consideration, I've installed a 12 volt shut off switch this morning. I put it in the center of the riser of the seat platform. The key locks in when it is on, and can be removed when in the off position.
Offline grouch
  • I'm recyclable!
Re: Taking Delivery
« Reply #609 on: August 11, 2017, 01:16:08 PM »
Excellent! Might not feel like it, but that was a _good_ dream!
Offline Chet
Re: Taking Delivery
« Reply #610 on: August 11, 2017, 01:41:47 PM »
 :) One of da few memories I have of my early childhood was driving my dad's cattle truck. My brothers and I found if we put dat big thing sticking out of da floor in a certain place, and one of us held down dat little nob on da floor, we could drive dat truck. We musta not figured out dat key thing, thank goodness.  :D  My dad sold dat truck just before he passed away, which would have made me 7, and my brothers 5 and 6.
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Taking Delivery
« Reply #611 on: August 11, 2017, 03:55:30 PM »
Keep 'em coming.
Door panels could be wood, too.
Don't never say I don't listen or I'm not flexible. ;) :)  Like I've said, the truck will tell me what it wants to be and diamond plate? M.R. Truck has decided he do not want dat.  :D    PICS TO COME
Offline grouch
  • I'm recyclable!
Re: Taking Delivery
« Reply #612 on: August 11, 2017, 05:33:44 PM »
You reached back a long way for that one. Now I'm nervous. :)
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Taking Delivery
« Reply #613 on: August 11, 2017, 06:48:29 PM »
Offline grouch
  • I'm recyclable!
Re: Taking Delivery
« Reply #614 on: August 11, 2017, 09:59:04 PM »
Looks like it goes well with that running board. Mine can't be the only old eyes you're straining, though. I blew it up until it was just pixels and still didn't get a good look at it.
YOU PROMISED PICS! More than 1! Almost as bad as the beginning of this thread where you wouldn't reveal what you were up to.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Taking Delivery
« Reply #615 on: August 11, 2017, 10:01:45 PM »
Only one I have right now. That was mock up. My door hardware bezels are in paint and I have some gaskets to make.
Offline paul case
  • Original wearer of the PCM.
Re: Taking Delivery
« Reply #616 on: August 12, 2017, 05:55:26 AM »
SWEET!
Good on the safety measures too boss.
PC
pc
Offline sandhills
Re: Taking Delivery
« Reply #617 on: August 12, 2017, 09:36:43 AM »
Yes, SWEET!  I love it  8).
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
Re: Taking Delivery
« Reply #618 on: August 13, 2017, 10:17:32 AM »
This is no time for my Dyslexia to kick in.
Offline POSTONLT40HD
  • G29
Re: Taking Delivery
« Reply #619 on: August 13, 2017, 11:00:17 AM »
For me wires are a nightmare...... especially what you're doing. May the force be with you.  :)
Where's the Spoon?
