440b blade valve
Started by ohiowoodchuck, March 14, 2017, 09:38:43 PM
ohiowoodchuck
I notice that while my skidder is sitting there idling the blade will raise up by itself. I figure the spool is not seating all the way or fluid is bypassing in the valve. Are these worth rebuilding or am I better just putting a regular valve on there. I hear there was a updated valve that was way less complicated but haven't seen a part number. If anybody has changed there's over could you post some part numbers please.
Education is the best defense against the media.
snowstorm
Deere made a update kit to replace the blade valve. Back in the  80's . Now your on your own. You need a closed center valve. You will have to build a bracket to mount it. I changed mine over a long time ago
ohiowoodchuck
Got any part numbers on what you used
snowstorm
Buy a closed center valve. Build a bracket to mount it. A couple tees oil in and return. You can use the lever that is there.  It was 25 yes ago that I did mine
ohiowoodchuck
I found a certain place selling newer conversion kits, but 400 is to much to spend for a 100.00 valve.
snowstorm
if that includes everything to convert it its a bargain.
ohiowoodchuck
it appears to be just a valve with a block mounted to it and maybe all the hoses go into it, vs having to buy the tee fittings etc.
