Moisture Meter
Started by wng-2, February 24, 2017, 06:23:55 AM
wng-2
I suspect this topic has been covered. What is a simple effective hand held unit?
Rich
Berwick,Maine
Woodmizer LT-15
Kubota L-4400
GeneWengert-WoodDoc
For checking dry lumber, either a pin meter or pinless meter will work.  Spend no less than $200.  Buy one that is made in America.  Delmhost Instrument Co is in NJ, so that might convenient for you.  Both types of meters have pluses and minuses.  I guess that for the most accurate numbers, I would use a pin meter, as it allows measurement of moisture at different depths, but it is slower and takes more effort than the pinless.
Den Socling
To add to what Gene said. a pinless like a Wagner covers a much larger area quickly and doesn't leave holes.
wng-2
Rich
Berwick,Maine
Woodmizer LT-15
Kubota L-4400
You can do what I did and just get both  :D.
123maxbars
I use the wagner meter that woodmizer sales, very good meter, but be prepared, when I got mine and started checking my wood i realized the kiln I was using was not drying my wood properly, Its a great tool to have in  your box.
Sawyer/Woodworker/Timber Harvester
Woodmizer LT70 Super Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
scsmith42
Merlin makes a very high quality meter, several models of which will read to the proper depth for 8 and 12/4 lumber.  They are close to $500.00 though.
Be sure to check the depth of reading specs before you buy a pinless meter.  Most on them only read 3/8" deep.
Tom's 3638D Baker band mill
longtime lurker
I use a Delmhorst J4: if I wanted total precision I'd oven dry a sample, for everything else it's accurate enough, and the slide hammer pins come in handy at times.
Pinless would be nice but I can usually find a place to take a reading where holes won't show, and I've had issues before with pinless meters due to the presence of treatment chemicals on the wood throwing electrical resistance out.
GeneWengert-WoodDoc
Check the Appendix in Drying Hardwood Lumber for comparison of moisture meters.
