Thinking About Adding CNC to a old wood lathe.
Started by 21incher, February 21, 2017, 05:23:23 PM
21incher
I am trying to figure out how to convert my wood lathe to be able to duplicate parts and decided I would try and add a CNC assembly to it. I figured this would give me a chance to learn how to use a Arduino to control it without spending a lot. It is amazing how much info is available on line so I spent the last couple of days getting started. I just made a video showing how easy it is to get started using a Arduino for control.
https://youtu.be/ebbizXvjfN0
It will take me some time to get everything together to finish it, but I am amazed how easy and cheep it is to get started with the Arduino for automation. Still trying to decide if I will try and use a cutter or trim router to do the cutting. :)
Den-Den
I will be watching this thread, mostly to see how you handle the mechanics of the motion.
Darrel
I will be watching this thread so I can learn something and not have to do all the research.
1992 LT40HD
Ljohnsaw
So only 2 axis on the spinning lathe?
How well do you think this would work for a CNC router table setup like the one you have?
John Sawicky
Darrel
It will really get interesting when you start doing hollow forms.
1992 LT40HD
21incher
Quote from: ljohnsaw on February 21, 2017, 11:17:10 PM
Yes to start out. I just plan on adding a x and y for profile turnings. Fusion 360 can create the cam for it very easily. This project is just to learn about the Arduino because in the future I want to build a portable CNC router sled for my mill rails to surface slabs that is controlled by my cell phone . GRBL is set up for 3 axis control and many people use it for CNC routing. You just have to watch which USB chip is on the Arduino for GRBL use. The real low cost boards have communications issues.  :)
Quote from: Darrel on February 22, 2017, 12:09:53 AM
I don't plan on that. This will just be used to make legs and spindles.  :)
Kbeitz
Wow does this bring back memories. Way back when the Commodore 64
computer came out I got into this. I started building my machine in 1987
Using the Digital I/O interface board SS100. I made a relay box to handle
a larger load. I put my 3 axis unit on a Grizzly mill drill. Last picture is
one of the things I made with it.I don't use it much anymore. It sure was
fun to build and use.  I will be watching you'r progress. Wishing you was
in my backyard.
Love machine shop work
and Wood work shop work
And now a saw mill work
21incher
Kbeitz, I still have my Commodore 64 with all the accessories, game cartridges, cassette tapes, plus the 300 baud modem. I just pulled it all out and going to put it on craigslist to see If it has any value. That little mill would be easy to convert to Arduino control and be real easy to use with g code to give you a cnc setup. I think you can even get low backlash ball screws for it on eBay. These little controllers could easily replace all the big old counters that you use for projects and are all programmable in C. The best part is they are only a couple of dollars so it is not a big hit if you fry one.  :)
Kbeitz
Put that Commodore 64 on E-bay. Completed auctions shows one that
just sold for $800.00... Other at around $400.00
I will look into that Arduino control.
Thanks.
21incher
Got the control box finished up today. Starting to scrounge some mechanical parts to modify the lathe.
https://youtu.be/ymwb1ys_JIg
Hoping to use the same box in the future with 7 amp drives if this works out to make a garage door chain driven cnc router sled for my mill trailer. It would be nice to be able to route 2 ft x 12 ft signs and flatten slabs. :)
