WM PM Q
Started by 4x4American, February 17, 2017, 09:20:55 PM
4x4American
Okay now which one of you organized sons uh guns has the part number for the hydraulic filter used on a 2014 WM supah hydramobolical?
And how many hours do you grease this guy? (see picture)
Boy, back in my day..
4x4American
Does this look bent to you?  lol lol
Percy
Quote from: 4x4American on February 17, 2017, 09:25:13 PM
Ya it looks bent. Still works?? I'm bent and I still work.....I think...
4x4American
Yup, still works, WM is like a Rolex watch, takes a lickin and keeps on a tickin!  Had a board jump over the dragback hand unit and kersmash the motor.  Still works, so if it ain't broke, don't fix it!
Percy
I wish I was able to lift my dragbsck at the push of a button. The lt 70 is a bit of a process.
dgdrls
GM,  What does the motor drive?
D
terrifictimbersllc
Quote from: 4x4American on February 17, 2017, 09:20:55 PM
My 2001 super uses a NAPA 1551 filter.  I usually get all my parts from WM but in this case got a dozen of these when they were on sale at NAPA for some ridiculously low price. My log splitter uses same one.
Do you know about woodmizer.com>my account> log in>shop parts>select your sawmill>sawmill parts, hydraulic system, hydraulic pump box> ?
on my machine it is item 29, part #20301, hydraulic filter
Cant see the nipple on your underside there.  What are you trying to show us?  :D :D ??? ??? :P :P
Bandmill Bandit
if that is the nipple on the idler bearing for the head lift shaft I grease mine 2 times a year.
fishpharmer
Quote from: dgdrls on February 18, 2017, 07:18:54 AM
D
To the right of the motor you can see a small cable attached to the metal angled downward.  That metal angle downward is a board dragback.  The motor winds the cable to pull the dragback up out of the way, or unwinds to let the drackback down.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
4x4American
Thanks fellers.  Dennis no I didn't know about that, will have to do some further playing around with that.
