Video of WM manual toe board and turner??
Started by Brad_bb, February 08, 2017, 07:18:03 PM
Brad_bb
Ga Mtn Man,
That is what a toe board should look like.  Gotta have bearings rated at the proper load.
What do you think the load on a toe board should be figured at?  What I mean is, what weight of log on the roller should you account for in design? Plus margin of safety?  1500 lb?  so 750 per bearing?
Ga Mtn Man
I'm just a picture poster, someone else will have to weigh in on that question.  Know any makanikul injunears?
47sawdust
When I had my KascoIIB I made a set of toe rollers like that.They worked great.We turned bushings out of UHMW plastic,inserted into schedule 40 pipe with 3/4'' cold rolled rod through the center.Backwoods engineering did the calculations and we were in business.
Mick
4x4American
I think 3500lbs total capacity per toeboard at min, for my application.  Because my loader is rated fir 5k lbs, and I want at least half of that plus safety factor.  You have a different mill.
Boy, back in my day..
Darrel
I've had a 5,000 pound black oak log on my mill so I'm saying 4x4 is not too far off in his estimation.  3,500 lbs per end would give the safety factor needed.
1992 LT40HD
