My First Walnut
Started by Upper, February 03, 2017, 04:04:29 PM
Upper
I have 3 eight foot by 16 inch logs,with 2 inches of sapwood.I don't know how long the tree has been down in a moist area,but the sapwood on the bottom wont hold a hook very well.I was thinking some live edge but I have read a little about uneven sapwood and such.My guess is no live edge and minimize the retained sapwood for just a little character.Thoughts?
Stihl 661
Alaskan 36 CSM
36" guillotine splitter powered by a GMC V6
I like to build stuff
LT35HD Wood-Mizer
WV Sawmiller
   i'd go ahead and try some live edge. The sapwood will fall off but you will still have a nice natural, native shape. You can always edge them later but you can't put the edges back on.
   I had a customer come by yesterday wanting some 2" cherry and all I had was native edges and he wanted squared boards. The mill was already set up so we just tossed them on it and edged them to fill his order and we were both happy. The next guy may want them native. Maintain flexibility where possible.
   Enjoy the walnut.
drobertson
Sap wood should not fall off, bark, yea, if steamed it takes away the sap wood coloring, air dried is fine too, just takes a while,
tareece
Hey Upper...
     Pics would be nice... but whats the worse that could happen? I have some rotten  oak that fell and its been laying down for 2-3 yrs... so im going to slice it and see if there is any worth left to it.. .or if its just ant and termite food
    Its always a gamble harvesting laying timber...
Todd Reece
Lover of many things. Experienced in most... expert in few
21incher
You can always cut it off later, but can't put it back on. I have never seen sap wood fall off.  :)
Upper
Thanks for all the replies,looks like I will slab it,Girlfriend wants a table.Told her she has two years to settle up.
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
Kbeitz
I have some walnut that the sap wood fell off of.
Some I needed to give it a little nudge but not much.
Love machine shop work
and Wood work shop work
And now a saw mill work
WV Sawmiller
   I haven't been doing this as long as some of the folks on this forum but I have had several live edge oak, walnut and cherry slabs where the sapwood was pithy and would rub right off and even some that looked like shake between the heartwood and sapwood where the two separated.
Darrel
I've seen the sap wood rot and fall off many different species of wood, redwood does it all the time. Black oak does too
1992 LT40HD
DannyLand
In my limited experience with walnut, the sap wood will rot off but the heart wont, so leaving it to lay in the dirt wont really harm it, but this may not be the case in all states and weather conditions.  I personally havent seen it separate without some help from mother nature in advance.  I have however intentionally cut and sanded the sap off to reveal the natural shape of the tree for a fireplace mantle for a customer.  Took a lot of work but it looked great and would be thrilled to have it just happen naturally.
Woodland Mills HM126, Hudson debarker, Jonsered 2171, New Holland skid steer, 1955 International Harvester Dump 132
YellowHammer
If the sapwood is rotted or weak, I'd take it off.  If it's not structurally sound enough to take a hook, it not sound or strong enough to make a good table or board edge anyway.
Normally, on sound walnut and cherry especially, face sapwood will almost always pull, and will cause the boards to dry poorly.  Typically, I try to get at latest a 90% sapwood free face, or the boards will bow, or at least have enough stress to want to bow or move, especially on 4/4 boards.  So the solution is to slab heavy.
However, balanced sapwood borders on the edges of a thicker live edge slab are different, and work well, and will generally not warp the slab, and they look great, only because they are pulling the slab evenly.
Of all the defects due to drying and sawing, the hardest to remove is bow, and that is generally caused by log stress or sapwood pull.  The solution to bow is jointing, or cutting low boards into short pieces, and then jointing, so long thicker defected boards turn into thinner pieces of wood real quick.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
alanh
Also got a load of walnut, mt first. I cut a 5` long crotch of a 14" diameter log, cut 4 slabs and put them on cl, sold them all to the first caller and gained a connection with a furniture guy...
Darrel
Those are awesome looking slabs!
1992 LT40HD
Upper
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
Upper
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
Upper
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
Upper
Should have sawn this one with the check
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
Upper,  before posting pictures, I always like to click "Preview" and then scroll up to see what the reply will look like.  Also, after you make a post and do not like what happened, you can click "modify" and correct any mistakes.
Den Socling
Did you sell those slabs green alanh? That figure is probably going to develop surface checks.
Live edge walnut slabs with sapwood are sold by the gazillions. I have a couple thousand BF in a kiln at the moment.
Upper
Thanks Magicman,I too now will like to do it that way.I am so jazzed to be able to post pictures.
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
And you are jazzing us with those pictures.   smiley_thumbsup
