Comstock Logging
National Salvage & Service Corporation
Author Topic: Help with woodcraft 30-20a part  (Read 1045 times)
Offline Biggesawmill
  • I am new
« on: January 10, 2017, 06:10:00 pm »
1st off I would like to say thank you for letting me be a part of the forum. My father has a woodcraft 30-20a sawmill and I am trying to find a worm gear (speed reducer) for the hydraulic motor the lift's the bandsaw up and down. This is what happened the short chain got loose and stretched out and it jumped a tooth a couple of times and busted both sides of the gear box I took the gear box completely apart and I can get the bearing's and oil seal's locally (I have been a diesel locomotive mechanic and hay baler mechanic most of my life so rebuilding this gearbox was going to nothing... I thought) it busted both sides of the gear box housing and there is no information on the box. And we have no manuals or parts breakdown either my father bought it used about 10 years ago and there was no information that the owner had. I have looked all over the Internet with no luck. The Shaft on the hydraulic motor is 1in. Any help or information would be greatly appreciated thank you for your time.
Offline Brian_Rhoad
  • I am new
Re: Help with woodcraft 30-20a part
« Reply #2 on: January 10, 2017, 07:17:35 pm »
Thank you I will look there 1st
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #3 on: January 10, 2017, 07:26:34 pm »
I think the first thing you need to do is try to put it together just
good enough so you and turn it by hand to find the ratio.
Then I don't think it would be to hard to find a box.
We have a good source for that kind of stuff about 30 miles
from here It's called Trates Surplus. 570-742-2101 ask
for Gary. Tell him Kevin sent you. Also get your shaft sizes.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline ozarkgem
  • age 65 yrs old
« Reply #4 on: January 10, 2017, 08:20:28 pm »
If its broken you can also count the teeth and get your ratio that way. I would guess its something off the shelf. I doubt  they had a special gear box made.
  • I am new
« Reply #5 on: January 11, 2017, 12:54:47 am »
I know that the gear has 42 teeth on it. I will give the them a call tomorrow and the inside of the the bearing  housing has a BH60CL and inside of the plate where the hydraulic motor connects is a 6A056C060 any idea's
Offline Kbeitz
    • My Hobbies
« Reply #6 on: January 11, 2017, 08:40:50 am »
I would not know how to count the teeth on a worm gear...
Could you explain that part for us ? You would need to
know how many teeth moved across per one turn i'm
guessing... ?  So this would be 12 to 1 ?
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline ChugiakTinkerer
« Reply #7 on: January 11, 2017, 12:23:42 pm »
Welcome to the forum!  Hope your dad's sawmill is up and running shortly.
Woodland Mills HM130
  • I am new
« Reply #8 on: January 11, 2017, 04:46:48 pm »
That's good information on how to get your gear ratio thank you
Offline ozarkgem
  • age 65 yrs old
« Reply #9 on: January 11, 2017, 08:48:46 pm »
[/quote
since its broken you can take the worm gear and manually turn it on the spur gear or figure the threads per inch on the worm and one revolution will travel x distance and the spur gear is x diameter . I don't know if the nomenclature is gone or not that would be easiest. Most likely 30 or 40 to one. If its not set up with presets may not make that much difference which one you choose.
  • I am new
« Reply #10 on: January 17, 2017, 12:38:24 am »
Update on my dad's sawmill. I was able to go by and get the gear ratio. It took a couple of times to get it right we got it. It is a 40 to 1 got everything measured and I think I will got one located I will find out on Tuesday. Thanks for all the help
Offline Kbeitz
    • My Hobbies
« Reply #11 on: January 17, 2017, 05:50:48 am »
Six listed on E-bay right now....
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
  • I am new
« Reply #12 on: January 17, 2017, 11:51:25 am »
OK thank you Kbeitz I got a call into Gary but I haven't gotten a reply yep. Again thanks for the all your help as well as everyone else.
  • I am new
« Reply #13 on: January 18, 2017, 01:28:20 am »
I spoke to Gary today and sent him some pictures of the gear box and he told me that it would be thur possibly before he can check to see if he has one. Thanks again for the help
Offline Kbeitz
    • My Hobbies
« Reply #14 on: January 18, 2017, 08:44:36 am »
Thur and Fri is the only days that they are open.
If anyone gets a chance to see this place it takes days to look at it all.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
