Tortion box plainer sled
Started by Joey Grimes, January 08, 2017, 09:10:15 PM
Joey Grimes
I finally built a tortion box so I could true up twisted or bowed live edge slabs it works great .It is 2# 2 foot x 8 foot pieces of plywood with a 3/4 ×1 1/2 grid 12"x12"in the middle glued an screwed.It is a rigid true box that the slab is then wedged so the feed rollers don't push flat then run through plainer till you have a wide enough face to turn it over and run without the box .I'll post some pics when I build another as this one was a test to see if it would work.
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
YellowHammer
I'm definitely interested in seeing pictures.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
petefrom bearswamp
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Larry
I've never used a torsion box, just a plywood sled.  Even the slab with wedges held tight with hot melt.
Eager to learn a new way.
Joey Grimes
I'll have some pics end of week I've recut on the sawmill in the past but this works better to maximize thickness.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Joey Grimes
That is almost more slab than planer.  How is the kiln running?
Joey Grimes
Kiln is doing great It's cranking our the wood now that I'm learning how to operate it.
