Found an Extra Part from my Saw
Started by YellowHammer, January 08, 2017, 08:54:57 PM
YellowHammer
I was milling some cherry today with my LT-40 and found this little piece of metal laying under the saw head in the sawdust.  I didn't have a chance to look to figure out where it came from, but I figure the rest of this is still attached to something important.  Does anybody recognize where this part came from?  It must be a spare, my saw was running fine.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
4x4American
Oh that's part of the cherry bucket that grows in all cherry trees.  I've sawed out many of them.  It might have fell out when you flipped the cant.
Boy, back in my day..
scleigh
Looks like part of the brake on the drive wheel
paul case
pc
Ljohnsaw
I bet Marty will have the answer!
Whatever it is, looks like the casting has been broken for quite some time and it came from an area where it rubs a lot - like near the belts?  Is there some sort of latch on the exhaust chute?  Maybe the sawdust blowing on it was keeping it so clean on the one side.
John Sawicky
terrifictimbersllc
Looks like a piece of an automotive type part like an alternator  or disc brake caliper bracket , not a sawmill  part, to me.
slowmiller
Alternator belt tensioner casting maybe? I had a similar part "show up" while milling and that is where it came from.
Haven't sawn any cherry that have alternators, yet.
dean herring
It looks like it is definitely broke off from something else. Could it be from the clutch?
Failure is not an option  3D Lumber
Ga Mtn Man
MartyParsons
Hello,
  If you have a alternator belt tensioner on a 51 Cat or Yanmar? Not sure that is the only place I can think that is cast aluminum? like that.
Marty
YellowHammer
Quote from: Ga Mtn Man on January 10, 2017, 11:30:33 AM
Did you figure it out yet?  ???
Nope, I have taken off pretty much every cover I could, and can't see where it came from.  I have checked the alternator tensioner and it's fine, as well as the other aluminum components as much as possible.  There is packed sawdust in the part as shown in the picture, and eroded corners, so it's seeing material pass over it.  I'll keep investigating, but the mill is running fine, so it's time to get back to work.
YellowHammerisms:
Kbeitz
It's part of the landing gear from the 727 that flew over last week...
Love machine shop work
and Wood work shop work
And now a saw mill work
JIM GORMLEY
Its part of a delfleccio valve. Its obviosly missing the finnigan pin.
I live with fear and danger. On the weekends,I leave her and go wild boar hunting.
Kbeitz
Quote from: JIM GORMLEY on January 12, 2017, 10:59:45 AM
Yea I bet the self sealing stem bolt sheared off...
YellowHammer
I'll find it eventually......when the other half of hits the sawdust.
I think it may be my main throttle sponder. ;D..reminds me of this song by Alan Jackson
https://m.youtube.com/watch?v=Kn2IaQ7ECUY
YellowHammerisms:
redprospector
I like Allan Jackson. He's one of the last country singers to actually sing "country".
