Comstock Logging
Author Topic: Rebuilding a Belsaw M-14  (Read 4186 times)
Offline Dieseltim
  • M-14 Project
Re: Rebuilding a Belsaw M-14
« Reply #80 on: April 12, 2017, 08:42:16 pm »
Poor old frame is just about to fall apart.
Offline Trapper John
« Reply #81 on: April 13, 2017, 01:57:12 am »
Tim, I was wondering how you will run the cable with those full height cross members.  I think you will have to use two pulleys at each end, one above the other so you can clear those cross members.
Offline Dieseltim
  • M-14 Project
« Reply #82 on: April 13, 2017, 12:38:28 pm »
Trapper,
I plan to use a trailer axle for the hubs and install rims for pulleys.
Offline BigZ La
« Reply #83 on: April 13, 2017, 10:38:20 pm »
Keep up the good work, I'm getting plenty of ideas here. Thanks
Offline Dieseltim
  • M-14 Project
« Reply #84 on: April 18, 2017, 08:58:25 pm »
Anyone else ever thought about modifying the log dogs to get a bigger log under them? As i measured from the point down I only had 20" , but if you turn the dogs over you can gain almost 7 more inches. So, just cut a few teeth in the top side and put a removable pin in the backside, and now if I ever need it I'll pull them out and flip them over and have an extra 6+ inches of space under the dog, for those bigger ones.
Offline Darrel
  • Gettin' it done!
« Reply #85 on: April 18, 2017, 09:05:15 pm »
Now when you get the bigger saw blade, you'll be all set.
1992 LT40HD
The winds of change are blowing at hurricane force and I don't like it but good shall come even though I see not how.
Offline Dieseltim
  • M-14 Project
« Reply #86 on: April 18, 2017, 09:09:58 pm »
Ok paint colors have been selected. Orange with black for details. Got to love Rustolium.
Offline Dieseltim
  • M-14 Project
« Reply #87 on: April 22, 2017, 07:29:14 am »
Got most of the carriage painted. I don't really think it will stay that way long once I start putting logs on it, but it should keep it from rusting more.
Offline Darrel
  • Gettin' it done!
« Reply #88 on: April 22, 2017, 03:55:18 pm »
That heavy frame almost makes the carriage look insignificant.
1992 LT40HD
Offline Dieseltim
  • M-14 Project
« Reply #89 on: April 22, 2017, 09:43:54 pm »
Well not really any pics of today's progress, spent most all day with a laser level and a shovel. In the end, I think it is within 1/4" from one end to the other. At 66ft long I think this is pretty good. 8)
Offline bandmiller2
« Reply #90 on: April 23, 2017, 07:01:26 am »
Tim, whats really important is front to rear track as any inconsistency would cause the log to shift slightly and rub the saw plate. Keep up the good work mate. Frank C.
Offline Dieseltim
  • M-14 Project
« Reply #91 on: April 23, 2017, 05:35:23 pm »
Frank,
I'll see what it looks like tomorrow. We have had rain all day today. Maybe 1-2 inches. If it's going to settle any it should have by then. I'm estimating that this thing is almost 8000 lbs. Each of the 4 parts is about all my Kubota tractor wanted to pick up. I know she is starting to get old but it was rated at 2000 lb lift on the front bucket and curl of 2800 lbs. I also know that our bucket truck is rated at 11000 lbs right at the truck, but it will not lift the whole frame.
So, if weight matters much in this project. I should be good. Lol
I had it level at all 6 places, meaning both ends and the middle of both rails with my laser level. It was beeping at all 6 points saying they were the same.
We tampered all the pads before setting it with the boom truck. Then checked it with the laser and moved it off the pads to adjust it till I was happy that all 6 places were as close as we could get them.
Offline Dieseltim
  • M-14 Project
« Reply #92 on: April 23, 2017, 07:41:50 pm »
All 6 feet are welded to the legs. Each foot is 12" wide, with the total of 40 square foot for this beast to sit on. That comes out to about 200 psf.  8)
Another job over engineered again.  :P
« Reply #93 on: April 23, 2017, 10:48:49 pm »
Tim, I am thinking that sturdy frame will simplify any leveling or plumbing issues.  How are you going to mount the track, directly on your frame with shims or with some kind of rail system?
Offline Dieseltim
  • M-14 Project
« Reply #94 on: April 23, 2017, 10:58:17 pm »
I was planning to pull a string from one end to the other and see how flat it really is, then if I don't need much for shims I will weld it right to the top of the frame.
I keep reminding myself that this was originally just a wooden frame that moved every time the humidity and temperature changed.
« Reply #95 on: April 24, 2017, 02:29:26 am »
Tim, I am curious how your system will work over time as I was thinking of a similar system.  You probably don't have much frost in Georgia but you have rain and you are not on piers.  Probably work fine with the low ground pressure and the strength of the frame.  If it settles it will probably settle as a unit.
Offline Dieseltim
  • M-14 Project
« Reply #96 on: April 24, 2017, 06:23:11 am »
Trapper,
I'm planning to cover the feet with red clay dirt after a few months of setting, just to make sure it doesn't move. But, I can tell you that the frame is so stiff, that from side to side it will lift a leg before it twist.
The only way it seems to have any give is from end to end, it did have some sag in the middle before I leveled it.
As far as frost and freezing is concerned, in Ga. where we are, we have a 6" rule here. Most winters we only get a heavy frost. Only about every 10 years will we get a hard freeze. Same for snow.
