round edge sawing question
Started by Jim_Rogers, December 07, 2016, 09:11:30 AM
Jim_Rogers
I wanted to ask you guys about how to go about sawing a 2" x 24" x 14' piece of eastern white pine with round edges on both sides and have it come out right. And by come out right I mean that it is 24" on both ends without any taper.
I was thinking about this should I get the order mentioned in "What are you sawing".....
If I saw it as I would normally saw a log with the pith level to the bed:
I'm going to get a piece that is wide on one end and narrow on the other, right?
But if I saw parallel to the bark like this:
Won't the piece be the same width from one end to the other?
Jim Rogers
PS. If not this way, how would you do it?
LeeB
If the log is tapered and you want live edges you will get a tapered board out it.
Ga Mtn Man
You will need to raise the small end so that the blade exits the log where it is 24" wide.  Think of it this way:  If the log is 24" diameter on the small end where would you need to cut?  The blade would need to exit the log at the pith, on the small end.  If the log is 30" on the small end you would need to exit somewhere above the pith.  Where depends on the diameter of the log.
Remle
Ga Mtn Man is correct. Simply measure each end of the log as to where you reach 24" across and level those two points. Of course this will also cause a Significant Decrease in the Structural Integrity of the piece by cutting across and through the growth rings.  The closer the two end diameters the less effect on the Structural Integrity of the piece. One would be well advised to explain this to the buyer..
Ljohnsaw
Or, trade your eastern white pine for some western Lodgepole pine that has virtually no taper in 14'! :D
DDW_OR
when i picked up my sawmill at http://southwestideas.com i saw this in their showroom
Kbeitz
Remember that your live edge on the butt side is not going
to be flat. It will have the curve of the log in it if not centered.
Love machine shop work
and Wood work shop work
And now a saw mill work
Jim_Rogers
Quote from: Remle on December 07, 2016, 10:52:48 AM
Yes, I believe this method will give me a 24" side piece from end to end. And I do understand that this will have some cross grain to it but hopefully not much.
I will photograph it when and if I do it.
Thanks to all for your advice and comments.
Jim Rogers
fishfighter
If your white pines are anything like our southern SYP trees, most butt logs that are 24" on the big end will carry 24" at 14' up.
4x4American
Go to a big lumber yard that sells live edge bartops, and sort through until you find what you need, buy it, and then sell it to your customer for more $.  That's been one of the easiest ways I've found lol.  Theres a sawmill near me who sells pine bartop slabs for $20/ea to me.  For that price I find it cheaper and easier to buy and resell lol.
If you have to saw it yourself, just measure twice and cut once.  Def. tell the customer about slope of grain but I'm sure he ain't gonna be driving a truck over it so it may be fine
Boy, back in my day..
Brucer
Jim, by measuring 24" across both ends, if there's any significant taper you won't be sawing exactly parallel to the bark -- so use the methods suggested in the previous posts.
I doubt that slope of grain will be an issue. From the Softwood Grading manual ...
For Select Structural grades (the highest of the structural grades)
  Structural Joists and Planks -- maximum slope of grain = 1:12
  Beams and Stringers -- maximum slope of grain = 1:14
That means in a 14' long plank, you can deviate 1 foot from being parallel to the grain over the length of the log :o. You won't be anywhere near the maximum -- not even close.
Bruce    LT40HDG28 bandsaw
Jim_Rogers
Thanks for everyone's advice.
Jim Rogers
kelLOGg
Interesting job, Jim. What are the large and small end diameters of the log?
Bob
Peter Drouin
Jim_Rogers
Quote from: Peter Drouin on December 08, 2016, 05:52:42 PM
Get some logs with no taper.
Easy to say, not so easy to do.
kelLOGg
I have one log picked out from the pile but I haven't measured it up yet. The pile was a little icy since it snowed the other day and I didn't want to try my luck climbing up on it to measure it.
I will when I get the deposit.
Jim Rogers
