Removing Permanent Haze From Ceramic Glass
Started by Hullspeed, November 18, 2016, 07:27:15 PM
Hullspeed
Here's a video demonstrating the use of cerium oxide powder to remove heavy etch damage from a piece of wood-burning insert ceramic glass.  This is what you can do if the haze is more than just a simple layer of soot or ash on the glass.  If you skip trying to video record it, you can probably go a lot faster than I did.
https://youtu.be/fob94kf7eSs
peterpaul
Paper towels, 1 wet dipped in ashes and 1 dry to wipe the slurry off the glass works for me.  Easy takes me about 5 min. to do both sides.  Cleaned them this morning and they look like new just like in the photo below.
Woodmizer LT15, Kubota 4330 GST, Wallenstein FX 85, Timberwolf TW6, homemade firewood conveyor
Ljohnsaw
I have a gas fired fireplace.  It gets some sort of soot build up, how I'd don't understand.  I guess my gas company is sending me dirty gas :D  It wouldn't clean up completely with just glass cleaner.  I used a straight blade razor and scraped it off with that.  The glass was not etched but I will keep this tucked away for the future.  I (will) have a wood stove in my cabin.
John Sawicky
Dan_Shade
lots of dull bands and chains
