Show Me Your Sawmill "Sheds"
Started by pwrwagontom, November 05, 2016, 04:28:38 PM
pwrwagontom
Hello Everyone!
I got a brand new Woodmizer LT10 sawmill about two months ago.  Everyone on here predicted that this would happen after enough sawing with my Granberg MKIII.  You were all right! 8)
Anyhow, I've just lost my summer help for the winter, and I'm trying to get plans together to build a new smallish building to house the sawmill next summer.
I am imagining a simple wall-less structure, with just a roof, but as I'm brainstorming ideas, I'd really like to see some pictures of the designs which you guys have come up with!
Thanks!
Never give an inch
Kbeitz
Quote from: pwrwagontom on November 05, 2016, 04:28:38 PM
Hello Everyone!
Thanks!
Wall-less... I'm in... Just started it.
Love machine shop work
and Wood work shop work
And now a saw mill work
kelLOGg
Here's mine. It is about 32 x 16.
ozarkgem
Quote from: Kbeitz on November 05, 2016, 05:07:31 PM
Hello Everyone!
Thanks!
Thats one way to use pallet racking.
Kbeitz
Quote from: ozarkgem on November 05, 2016, 07:10:20 PM
Hello Everyone!
Thanks!
Sure was tough drilling. Had to re sharpen the bits after every hole.
ncsawyer
Mine is 20X48.  24 foot opening at mill.  Homemade 20 foot trusses.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
paul case
My saw shed is a repurposed chicken house. 40'x400'. The drawback is a 11' door. Well it may be alittle wider now?
Lots of room out front to pile logs.
PC
pc
newoodguy78
Quote from: ncsawyer on November 05, 2016, 07:37:59 PM
That's a nice looking mill shed you have there. Just curious did you do anything special to beef up that 24' opening? Being from the northeast snow load is an issue, not having to deal with that would be a wonderful thing.
scleigh
16 x 100 with a 20' opening on both sides at the mill.
ncsawyer
Quote from: newoodguy78 on November 06, 2016, 07:51:00 AM
I have a 8x8 inch piece of angle iron that is 1/2 inch thick.
stanwelch
Woodworker, Woodmizer LT15, Stihl 026, MS261CM and 460 chainsaws, John Deere 5410 Tractor 540 Loader,Forks & Grapple, Econoline 6 ton tilt bed trailer
flyboy16101
A work in progress 32' x 12' with 9' ceiling. The main opening is 18' x 6' and the end openings are 8' x 8'. Eventually I would like to have it so I can close it all up when I'm not around
Wood-mizer Lt35, International 504 w/ loader, Hough HA Payloader, Stihl Ms290, Ms660, LogRite Cant Hook
tacks Y
Flyboy, Are you sawing a lot of ash? I was looking at mine this weekend and thinking of cutting it all to sell. Is it still good where you are? I hear in 5 years it will all gone here. Tom
coppolajc10
24x44 pole barn with 20' openings on each side with sliding doors, 2 12' overlapping doors on roadside.  steel beams for openings.  lot of snow up here, walls are good for keeping snow out.
You don't want to be doing this:
intead of this:
snow stays outside:
flyboy16101
Quote from: tacks Y on November 06, 2016, 05:55:05 PM
It is hit or miss around here. I have cut down some that had been dead standing for a couple years and they made good lumber then last year I had 6 or 7 at my step brothers place that had only been dead a little less then a year and the butt logs all split and cracked when they hit the ground. I have enough ash on my place to fill a couple log trucks but work is keeping me so busy I have hardly had time to cut lumber for my mill shed. I used mostly oak and poplar being that was what people around me were getting rid of and I didn't know when I would have time to saw it for other things. Where at in NW Pa are you located?
Sixacresand
Quote from: stanwelch on November 06, 2016, 03:44:32 PM
24 x 32 for my LT15
Stan, where is your pile of slabs and mountain of sawdust?   :D  Nice building, BTW.
tacks Y
Jemclimber
Quote from: Sixacresand on November 07, 2016, 08:35:10 PM
24 x 32 for my LT15
I know where that nice custom made 10' extension is.   ;D
lt15
woodweasel
stanwelch
John,  slabs get dumped in front of my neighbors OWB and sawdust pile is in the tree line  :D.  Thanks for checking on me ;D
Darrel
woodweasel, that looks all shiny and new!  It will look even better after there is some sawdust on the floor!  8)
1992 LT40HD
fishfighter
Y'all guys are pushing me to start building a shed for my mill. Just got way to much going on right now. :(
Kind of looking at something that is 16x 24' with no walls. I have to have it no less the 13' ceilings due to me using my backhoe to load my mill and flip big logs too! Also thinking of installing a rail system over head to install a electric wench to flip logs and load.
flyboy16101
fishfighter I was in the same boat as you, but it will amaze you how much time it frees up not having to wait on the weather and or daylight to saw.
fishfighter
I only saw for myself. I saw up lumber as I need, but I really need to get my mill out the weather. I also need a place I could get my backhoe out the weather too! So, size wise, I might add another 8'-10'.
