New Kiln Build
Started by ozarkgem, November 01, 2016, 06:09:36 PM
ozarkgem
Here is the start of my new kiln. The doors are from a real kiln that was used to make bath room fixtures. I bet they weigh 300 lbs. Had to set them with the backhoe.
sandsawmill14
looks like your off to a good start smiley_thumbsup
LeeB
Cedar for framing lumber. Don't see that everywhere.
ozarkgem
Quote from: LeeB on November 02, 2016, 11:28:03 AM
Wondering if anyone would catch that. It works very well for studs and I have lots of it.
drobertson
Looking good there Jim! Heavy doors!
YellowHammer
Nice build and hinges.  Many times, good hinges make the door seals work.  So you shouldn't have any trouble there.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
ozarkgem
So now I need a building to put dry lumber in. Will it ever end.
YellowHammer
Quote from: ozarkgem on November 05, 2016, 07:02:20 PM
Nope
:D
YellowHammerisms:
GeneWengert-WoodDoc
And then next you will need a sign that has a flashing red part that tells when you open.  Then you will next need a bank to keep all your money...etc.
How about we just fast forward to the bank part.
ozarkgem
Bank? Don't need one. I have a sawmill to put my money in.
PC-Urban-Sawyer
Quote from: ozarkgem on November 06, 2016, 05:33:23 PM
I hear deposits are easy but withdrawals can take substantial advanced notice...
Herb
