CB - 2400 Reaction Chamber Temps?
Started by stratford 50, November 01, 2016, 08:12:09 AM
stratford 50
Just curious as to what you are seeing for reaction chamber temps on the CB - 2400 model, Mine run from 1000 to 1700 degrees, Thanks Paul
boilerman101
I usually run 1,000 - 1,450 degree reaction chamber temps during my burn cycles. It's awesome watching how the correct amount of secondary air gets injected into the reaction chamber area depending on wood, wood moisture, coal bed depth and different times of the burn cycle through my wifi XP.
sam-tip
I mostly see 1000 to 1600.   Highest is 1800.    Anything over 1200 does great.  I have played with my primary and secondary air to get temp as high as I can.
I have found more primary and less secondary air works for me.  I was having to much secondary air and getting smoke.
Central Boiler E3200 WiFi
Many many ported chainsaws. 201 to 3120
TM log splitter pro30 6 way head
D&L 1020 swing blade sawmill for slabbing
Timberking 1220
