353Detroit slobering out exhast
Started by tantoy, October 22, 2016, 12:49:06 PM
tantoy
This is a follow up on this post.
https://forestryforum.com/board/index.php/topic,87208.msg1336260.html#msg1336260
This is what it looks like, oil drooling out exhaust.  The little pipe coming off the block behind starter is open, engine warms up to 180 and maintains, new air filter. I have never tripped the air flapper since rebuilding engine.
I thought injectors but BUSHMACANIC suggested blower seal, he was right.
So blower is coming off to see how I messed up installing seals.
1968 Garrett 20 Skidder
1991 Ford 1920 Tractor/Loader
2000 Takeuchi tb135 Excavator
Stihl 020, 041 Super, 084
Husqvarna 61, 181SE, 357XP
bushmechanic
Well tantoy I'd say there are only two possibilities for that... seal busted during cover install or you pushed the wear sleeves down the shaft too far. Like I said I had to develop my own method of installing those little buggers. Anyway I'm glad you found the issue too bad you had to mess up that nice paint job!
swampbuggy
Be careful when you pull it apart. There are shims behind the bearings that determine the vane clearance. Also look and the spring packs for the drive shaft. Its a shock absorber and they do get weak and break. It is also timed. Have fun! Dan
If it was easy, everyone would be doing it!
tantoy
Quote from: swampbuggy on October 22, 2016, 08:55:22 PM
Yep had the blower apart when i rebuilt engine so I know about the shims behind drive gears to adjust vane clearance. The spring drives only apply to 4-53 and up .
tantoy
Carefully dissembled blower last night. I was hoping to see a problem but to me every thing looked fine other than all the oil.  I was thinking maybe the oil return port on the capped, non drive end of the blower was plugged and the oil did not have a way back to crankcase, but that was not the problem.
So looking for ideas :)
The blower seals are much stiffer than a standard seal, I saw no tears or deformation though.
All 4 seals were riding on the collars right in the middle.
Does anyone see any obvious problems?
coxy
it may not be the seals  maybe a broke oil ring or2-3 if a skirt broke off the sleeve or piston wood that do it jus a thought  you will find out as soon as you put it back together
treeslayer2003
but, how would oil get in the blower then coxy?
is there a bushing or bearing in the housing the lobe shafts ride in? could be wore and allowing enough movement to wobble in the seal?
just a stab in the dark
bushmechanic
The wear sleeves are not the issue as they are installed perfectly. I have seen blowers where the collars are pushed right down to where they hit the white metal of the rotor lobe, then the seal only hits the edge of the wear sleeve. The seals look good but really inspect them for cracks. Look for a wear sleeve split also as I have saw those crack during installation. No drain issues you say with the block? That sure is a strange problem with that engine tantoy. So I assume the air box was completely full of oil also. If you don't have a severe air inlet restriction which would cause the oil to be sucked in through the blower seals then your problem just may be internal to the engine.
tantoy
Thanks guys for taking the time to reply!
I do have concerns that it may be oil going past the oil rings. In fact I think I will pull exhaust manifold and see if one hole has more oil than another.
Tree slayer; I agree , can oil from the block, around the cylinders make it back to the blower?? Good question.
The lobes in the blower do not have excess play in the blower housing.
Bush; there was not standing oil in the block around cylinders or in the air intake flapper housing.
Air intake and filter are all good as I hooked up the shop vac to make sure unrestricted flow.
I will pull exhaust manifold and report back.
bushmechanic
Good idea on the manifold to locate the troublesome cylinder. If all are the same then it must be a problem in the air box. Was there oil dripping out of the air box drain? You say there was no oil in the air box or no amount of oil? How many hours have you got on that engine since the rebuild? When you installed the wristpin retainers did you check them after for leaks? Maybe if one of the retainers is leaking it could spray oil into the air box from the piston cooling nozzle. If you haven't guessed I love a strange problem! I wish I was there with you now at that engine.
treeslayer2003
i still say the oil can't go upstream in the incoming air.
tantoy
Quote from: treeslayer2003 on October 26, 2016, 10:41:49 PM
Hoping your right as that would mean my rings and cylinders are not the culprit.
tantoy
Exhaust manifold removed.
#1
#2
#3
Number 2 seems to be "wetter" than # one and three.
Bought new gaskets and seals for blower and going to resemble.
coxy
I don't think its the blower  I still think its internal     jmop but if the blower was bad wouldn't it be wet in all  not 2 1/2
tantoy
Quote from: coxy on November 05, 2016, 02:09:19 PM
I agree,
coxy
did you do the rebuild or some one else
Neilo
There was so much oil in the exhaust that it could have wet what you see at least in #3, maybe #1 because they look dry inside the head.
bushmechanic
Well seems like a problem with number two cylinder. Looks like excessive oil in that one for sure. If the blower was all the problem you would figure that number three would be soaked with oil the worst as it is the closest to the blower in the block.
Puffergas
I'm sure this isn't the problem but if I remember correctly you don't load the piston from the top because the oil rings get chipped/cracked by running over the intake ports... or something like that. Just tossing that out there.
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, Trojan 114, Timberjack 225D, D&L SB1020 mill, Steiger Bearcat II
tantoy
I rebuilt the engine myself and it was my first diesel engine rebuild. I did not use brand new liners as they seemed ok so that could very well be my problem.
Bush, when you assemble a blower, do you use some kind of gasket maker on the blower housing to the blower end plates? No where I read say to use any type of gasket or gasket maker .
bushmechanic
There's no need for sealant on the blower center section to the end plates. I only use permatex #3 aviation gasket sealer on all gaskets when I do a Detroit diesel. I install the seals in the end plates then immerse the plates in boiling hot water for about two minutes, then remove from the water and install a couple of old collars into the seals. When I'm ready to install the rotors then I remove the collars and immediately put the rotor in the end plate. Had some pics took of one I did Friday night past but can't get them from my phone to this post... Grrrr !
treeslayer2003
maybe bushmechanic can help me out here......seems like there used to be an oil ring that could be installed from top. i know the last couple i have done came with a ring that almost barbed, ie cannot be installed from top with out breaking it. but it seems to me the old kits years ago had a oil ring more like a gas engine, flat. i could be remembering wrong.
tantoy i can tell you if you had the late oil rings installed from top, they are certainly broken.
ehp
I always put the pistons in from the bottom of the sleeve , I'm not brave enough to try that from above the sleeve :o
bushmechanic
As ehp said always load the piston into the bottom of the sleeve. Far as I know that is the way Detroit always installed them. Now in saying that I have seen the oil control rings that treeslayer2003 is mentioning. There are many different applications for the series 53 engines from skidder's to genset's to busses to marine and the list goes on. When you order parts they usually ask what the engine is in it so they can get the right type of ring set for it, the oil control rings are color coded, skidder's are usually violet and I have seen white among other colors.
treeslayer2003
bush it could be i was doing an emergency repair and got that type ring on purpose that time.......i can't remember its been 20 years or so. but your right, they are different color, this last one was kinda purple or violet as you say. no way they could go from top, i broke a couple going in from bottom. some were broke from shipping, i had to reorder so i got a full set of iol control rings.
