What zit gonna be?
Started by Jeff, October 21, 2016, 02:55:38 PM
I've got a little more to do.  If you look on the model t driveshaft, you can see where a guy could bolt something on. My plan is to find something among my junk to make a cooling reservoir that comes up to keep parts cool in as you grind.
You really like having a building.   :)  Lucky you.
I would suspect most of your welding will be done inside.
I took a 2 wheel dolly,and built a box right on it. About 2 feet wide,4 feet tall and maybe a foot deep. The welder is on the bottom,along with welded bolts to the bottom.One is for my grinding wheels and one is for my metal cutting blades. I did build one draw and keep my tips and wrenches for the grinder in there. I have a place for my clamping tools and have a bunch of corded wire wrapped up on the back. I forgot how much is there now,but it said it in the owner's manual how long. The corded wire was not cheap,but it was worth it. And then some. I just unwrap what I need.
That is one of many projects you will build. Every grown up boy needs a welder.
I use to get alot of short pieces of metal at my other job. My wife calls it junk,until she wants something built and I just go out back and look through the junk and build it for her. Than it's not junk anymore.  ;D
POSTON WIDEHEAD
Another stand built by Jeff-Rite.  :)
Brucer
I "learned" to weld in a night school course back in 1972. I haven't improved since. That's why everything I weld gets painted with flat black zinc-rich paint ;D.
Bruce    LT40HDG28 bandsaw
kensfarm
Jeff I have to ask.. what is that blue wheeled machine behind your new grinder table.  I think you could also use it as a mini welder table too.. nice first project.
That would be my unitractor that we got out of a field down to Bro Nobles place that I restored many years ago now.
sandsawmill14
jeff if you need another project i built a pantograph like on a sawmill carriage and put long leads on my welder now i can weld anywhere in the shop and about a 30' sweep outside the front door ;D
the cables are off of it right now  because i had to take welder out side to weld some out of reach of my cables and havent put them back up yet ::) sorry about the pics i couldnt figure out how to position the arm where i could get it all in the pic :-\ and please ignore the mess i dont keep as clean of a shop as i should :-[ ;D :D :D :D
David Freed
I missed out on the guessing, but that's a pretty useful project.
Quote from: Jeff on October 21, 2016, 02:55:38 PM
.......in my junk pile.
It's only junk to other people. To those of us that have piles like that, it's "stored building materials".  smiley_thumbsup
LeeB
Women are born with a basic defect that doesn't allow them to understand that a man has to have an as yet net assigned a project raw materials stock pile.
Roxie
Truer words were never spoken, Lee.   :)
Say when
sandsawmill14.I had forgot about that. Good idea!! At one job I had,in the Product Design area,they had a small ibeam with the welder attached to wheels and it was over head as yours is. It kept it out of the way and was much easier to get around a project. That only had one arm and the part that was attached to the wall and was on a bearing and could pivot.
In my case, that would be a bit rough to have the leads off a pantograph as it it a wirefeed. I do need to make or acquire a welder extension cord at some point
I should of said it was a wirefeed. It was one just about like mine,runs off 220,nothing was welded much over a ¼ inch in that area.
sandsawmill14
jeff  i built that out of 1 square tubing with a 1/4" with 1 1/2 pins in pipe for hinges so it would be strong enough to hang my little 125 lincoln mig from the end and run the cord down the arm to plug in :) the hose and ground are long enough to give you a 6-8' radius around the end of arm. :) i built that when we were working on a mill that i couldnt get but 1/2 in and 1/2 out of the shop (my shop is only 24 x 30 :-\ ) and the leads were always in a mess when i would have to go from one end to the other  :) i mounted it to the crane leg nearest the door so it will swing flat against the wall and the center pivot will let 1/2 the boom swing out the door :)
i am sure you will think of several projects now that you have a welder :) and if you dont have a big enough stock of metal to choose from go to the scrap yard and have a look around scrap is down right now and you can buy from them for around .05-.08 per pound right now ;) at least around here  :)
sandsawmill14
the cooling on the grind rock is a great idea  :)
Gary_C
That looks great including the welds I can see.
Just remember the wire for a wire feed welder does not like unheated buildings in cold weather. It tends to rust with the change in temperature and those small rust particles flake off the wire in your welding gun. There is a trick I've learned to take a paper towel or piece of rag and fold it over the wire and hold it in place with a clothes pin to clean any rust particles off the wire before it goes into the gun assembly.
What did you do for the Christmas Tree?
Maybe flux core wire don't have that problem? but I also put them packages that say,Do Not Eat, under my spool too. They come in electronic and other stuff.
OneWithWood
Jeff, I doubt you will ever quit welding.  The more you weld the better you get.
If you have not already built one I would suggest fabbing up a cart that will hold the gas cylinder as well as the welder and assorted clamps, tools, spools, gloves, helmet and maybe even a welding blanket.  Great practice and makes future welding chores easier to accomplish.
One With Wood
kensfarm
Quote from: Jeff on October 22, 2016, 11:00:20 PM
That is pretty cool.. you'll have to make a video w/ that bad boy in action.
I run my mig weldor off a generator.. so I had to make a cord because the generator has 120/240 sockets..  and the Hobart 210 MVP has 115/230 plugs.  I got 30ft of the AWG 10 3  wire w/ ground 600 volts & the socket/plug hardware at the box store.  I ran on the 120 until I made up the ext. cord.  Nice to keep generator noise at a distance.
Quote from: kensfarm on October 23, 2016, 09:33:21 PM
Make a forum search for Unitractor:  Here is one  The RustReaper thread shows it before restoration.   :o
Kbeitz
Quote from: Gary_C on October 23, 2016, 11:10:34 AM
You can but a little felt block that clips around the wire and it come with a fluid to
coat and help the wire travel through the liner .
Love machine shop work
and Wood work shop work
And now a saw mill work
Al_Smith
The only way to get to be a good welder is to do it .You'll figure it out .Once you get it down pat you'll remember for ever .
My bud and myself made an engine stand for Vo-Ag class when we were sophomores in high school .20 some years later at a sale of unused school property that item was sold .I thought my goodness we've came a long way from those humble beginnings .
Ox
I use what Kbeitz showed.  It's cut my liner replacement in half.  Tips last twice as long.  No difference in weld spatter.  Well worth it in my opinion.
Here is a greenhorn question. How do you know when your tip is getting bad?
