Clark 666D winch issues Question .
Started by RayMO, September 30, 2016, 09:39:03 PM
RayMO
Just curious if the hydraulic pressure should be 240 - 280 PSI at the test port on the front of the regulator valve at idle ? Thanks.
Father & Son Logging and sawing operation .
oldseabee
Thats with hot oil. fwd and reverse will be a little slow to come up due to soft shift modulation. If they are modulated there will be a valve sandwiched between the control valve and the case. all the clutches should be 240/280 within 5 PSI. including the free spool clutch.
