LT40 Carriage Feed Squeak
Started by Ga Mtn Man, September 27, 2016, 07:27:46 PM
Ga Mtn Man
My mill has developed a squeak in the carriage feed.  It does it if I move it by hand or using the power feed motor but is not constant, it comes and goes.  I took the chain loose so I could move the carriage by hand without the drive sprocket or idler roller turning...no squeak.  I turned both the drive sprocket and idler roller by hand and the drive sprocket using the motor...they both felt OK and I could not get either one to squeak at all.  Reconnected and tensioned the chain and the squeak returned.  It would seem that the squeak must be in either the drive shaft assembly or the idler roller.  Any one had this problem?  Any suggestions on figuring out which one it is?  Should I just ignore it?
BTW, when I took the cover off the feed assembly I discovered that the pulley set screw was loose and the pulley was shifting back and forth on the shaft.  This could have made a mess of either the pulley or the shaft.  Something to check on every now and then.
drobertson
Sounds like it could be a bearing in the feed drive, not a bad fix if this is it,
It could be either one Paul, but my money is on the shaft.  There is a bearing on each end and are fairly easy to replace.  LINK
If you have sprocket wear, it is bad economics not to replace them all and the chain as well.
Chuck White
Could also be a pieces of wood dropped down between the battery box and the main beam, but only touches once in a while!
Ga Mtn Man
I looked for that already, but I will check again before doing anything more drastic.  Thanks.
You already stated that it only squeaked when the power feed chain was connected and tensioned.
Ga Mtn Man
I know, but I didn't want to say that. ;)
Pull it down and find the problem.  You do not want a seized bearing race to slip on the shaft as mine did even though that shaft is only about $30 bucks.
In 14 years of sawing, I have had to replace those power feed sprockets and chain twice.
Ga Mtn Man
I will do that.  Your advise is much appreciated. Are the bearings a press fit on the shaft?
Yes, but not something that you can't handle.  I didn't have to use a press.
Notice the badly worn shaft sprocket above.  This sprocket/shaft unit needed replacing probably long before the bearing failed.  When you think about it, this power feed assembly is a real workhorse and takes a beating.
derhntr
Have had my set screw loosen up several times, 2nd time it was lock-tited.
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
