How to get rid of suckers growing off roots
Started by DR Buck, September 10, 2016, 09:19:30 AM
DR Buck
How can I stop these suckers from growing off the roots of the Magnolia tree?
Cut the magnolia tree down and spray the stump with Tordon  :).  Could be an extreme solution, though  :) :).  You would probably get some good lumber, too  :).
bucknwfl
I am with WDH. I can't see the tree itself but I see that a lot when trees are declining. I have had some success with a 50/50 mix of krenite and water on sucker sprouts after pruning limbs. I have not tested on magnolia yet but I just started one on sycamore and crabapple in the spring.  Krenite is a bud inhibitor
Buck
If it was easy everybody would be doing it
Dan_Shade
Loppers will cut them off if they aren't too big.   :d
lots of dull bands and chains
Chuck White
I'm not a Forester, but if it were in my yard, I would cut them off at ground level then mulch heavily with sawdust from my mill, but leave a little space between the mulch and the tree!
Carson-saws
Let the Forest be salvation long before it needs to be
Kitty
Quote from: Carson-saws on September 10, 2016, 01:12:34 PM
Vinegar
Carson, I am gonna try your suggestion ...getting rid of the tree is not an option at the moment...Thanks.
Kitty
(the other half of DR_Buck)
Kitty
Quote from: WDH on September 10, 2016, 10:28:39 AM
WDH, cutting the tree down is not an option at the moment...it is mature, very big, loaded with "character", lots of knots, twists and turns in the branches. Some of the knots have even formed a sort of old man with a long beard face.  I love this tree, just not the suckers. :)
Carson-saws
Kitty....the mix is....2 cups apple cider vinegar....1 cup epsom salt...cut the suckers flush to the area of growth...pour mixture over fresh cut...
LittleJohn
...lawnmower?  Just keep mowing them off each week
Kitty
Quote from: Carson-saws on September 15, 2016, 09:18:58 AM
Thank you Carson....I am going to do this over the weekend.
Thanks everyone for your suggestions.
Kitty
Quote from: LittleJohn on September 15, 2016, 09:35:21 AM
Little John....that would be a good idea if there were not so many exposed roots. A little rough on the mower..... :)
Jemclimber
That much magnesium sulfate mixed with acetic acid will surely kill the suckers.  I would be concerned about the rest of the tree as these suckers share the same roots as the mother tree.  I think a mechanical method (mowing or cutting) is a better option. Possibly lightly covering with mulch so the roots aren't as exposed so the lawn mower can do the job.  Good luck.
lt15
