Author Topic: Stem Wall or Monolithic Slab  (Read 1346 times)
Offline Believer
« on: September 07, 2016, 01:33:06 pm »
Wanting to add a small timber frame addition to the gable end of my barn. I want to put radiant heat in the slab (slab on grade).  Should I be thinking about a foundation and stem wall or a monolithic slab.
Offline sprucebunny
  • Gender: Female
Re: Stem Wall or Monolithic Slab
« Reply #1 on: September 07, 2016, 05:43:57 pm »
It would probably depend on your location (frost, heavy freeze) and soils.
Offline robmelby
« Reply #2 on: September 07, 2016, 09:28:07 pm »
 Your going to need ridged insulation under your heated slab. If you pour a foundation first, it will allow you to turn your insulation board down to a deeper depth on the perimeters. If you go monolithic , you'll need to incorporate your insulation in your forming. That could be challenging. So my vote is foundation.
Offline scsmith42
« Reply #3 on: September 07, 2016, 10:03:16 pm »
It is important to insulate the radiant heated slab from the outdoors.  Most folks insulate underneath the slab, but forget to insulate on the perimeter.
If you go stem wall, it allows you to insulate in-between the stem wall and the outer portion of the main slab.  Otherwise you have to figure out a way to insulate the outside portion of the monolithic slab, which is difficult to do in a way that survives over time.
Tom's 3638D Baker band mill
Offline ScottCC
  • New ideas welcome
« Reply #4 on: January 06, 2017, 07:54:58 pm »
I hope this gets to you.  I have the perfect detail for you.  Worked it out talking to nudura engineer and many visits to code department.  Have also had it stamped by structural engineer.  Email for drawing.  Have done it several times and the results can not be beat money-wise up front or heating bills long term.  I need to go learn how to post pictures to the forum.  Quickly, turn nudura brickledger upside down and pair with second brickledger.  Web is sized for necessary footer size. Only use one more course of block.  Cut interior side down floor concrete thickness.  2' of 2" insulation around outside.  Backfill as nessary.  Insulate interior, staple tubes down, wire mess over, pour all at once.  I simplified but you get the idea.  Happy to send drawing to anyone.
Necessity is the mother of invention.  Poverty is its big brother.  Woodmizer mp100, Woodmizer electric  lt15 wide with extra track, 71 Oliver allterrain forklift, 26' flat bed trailer, road legal log arch, homemade kiln, AutoCAD lt15
Offline Magicman
  • A "Traveling Man"
« Reply #5 on: January 07, 2017, 10:30:20 am »
Yes you do.  Follow this LINK for instructions on picture posting.  If you have any questions, just speak up.   ;D
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline ScottCC
  • New ideas welcome
« Reply #6 on: January 07, 2017, 09:48:02 pm »
I hope my picture shows the real thing.  Any ideas on extension required to take AutoCAD LT 15 and load?
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #7 on: January 08, 2017, 11:53:51 am »
Scott sent me the drawing here it is:
Jim Rogers
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #8 on: January 08, 2017, 11:56:05 am »
Here is the drawing attached.
Offline Don P
    • Calculator Index
« Reply #9 on: January 08, 2017, 10:05:17 pm »
That is slick  8)
 I doubt you need the outer discontinuous strands of rebar in the footer area
 I think chapter 4 of the IRC gives the depth and insulation depending on climate in their frost protected shallow foundation section.
Offline ScottCC
  • New ideas welcome
« Reply #10 on: January 08, 2017, 10:21:52 pm »
I did it this way bc I did not want a class action lawsuit in 20 years for all the log homes I plan to build on this foundation.  120 logs X 600 lbs seems like a lot.  And I picked the 2' in the ground scenario bc of uneven site conditions and landscaping near a home.  Drawing is in my gallery
