LT15 First start up
Started by 1Cross1WayLT15, August 28, 2016, 06:53:12 PM
1Cross1WayLT15
I'm new to the forum and new to the Mizer. Brand new lt15. Finished all assembly today. Trying to do first START-UP. (Using choke) Tried starting 30 times. Plenty of battery, got gas, got oil, engine cranks fine. However, it does act like it's not getting gas. The plastic cylinder (fuel filter?) in line with the gas hose has about a table spoon of gas in it. Should that cylinder be full? Anyhow, it cranks and cranks but no start. Am I having a gas problem or something else? This is a brand NEW LT15.
Rookie -
WM LT15 (w/ Power Feed).
Kbeitz
I allways put a little gas in an oil can and squart some in the carb
to see if it is a gas problem. Then I go from there...
Love machine shop work
and Wood work shop work
And now a saw mill work
tnaz
Welcome to the Forestry Forum 1Cross1WayLT15, as Mr. K has stated a little gas in a squirt can will let you know if its fuel or electrical.  A little fuel not a lot  because fire is easy doing this!!!!
Always have an extinguisher on hand.
Terry
breazyears
Check your plug after you crank it over. If its soaked than your getting gas. Put the plug back in the lead and crank it to see if you got spark. If your getting spark and gas you should get boom.
ETHURSTON
Chuck White
Welcome to the Forestry Forum, 1Cross1WayLT15!
Dave Shepard
Welcome to the Forum! Those little filters usually don't fill up all the way.
Oh man,so close,yet so far. Belt not engaged is it? I tried to start a brand new Troy Built with the belt engaged.  ::) I finally noticed and it started right up on the next pull.  ;D
welcome to the forum.
What's all the lumber going to be used for?
starmac
Dumb question I know, but it is full of oil isn't it. Many engines now have a low oil shutdown switch, and I have seen bad ones.
First, Welcome to the Forestry Forum, 1Cross1WayLT15.
I don't have any LT15 experience, but stating the engine size/type might help.
Seavee
Welcome to the forum.  My first move would be to look at the plug. Is it wet ? If yes check to be sure you have spark.  Things to look for is low oil, bad spark plug, yes a new plug can be bad. If plug is not wet  then a fuel problem.  Fuel can also not be pumped by a low oil problem.  Good luck  I'm Sure it's not to big of a deal.
Wood mizer lt50 47hp yanmar Diesel  Sthil MS311, Ms661 MS200T, 029 farm boss  and a New Holland T4  75hp.
Jack S
Is their possibly a safety shut off switch that might be off???
killamplanes
No help to your problem but welcome to the forum.
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
carykong
I had a bit of difficulty getting fuel to the carb on occassion.  Installed inline primer bulb,problem solved.
As a check, disconnect the fuel line at the carb and crank the engine and look for fuel flow.
terrifictimbersllc
If you've had the choke on all the time it could be flooded. Agree check plugs to see if they're wet and if there is spark.  If both then could be flooded. I have a 2 stroke outboard that does that sometimes if I squeeze the bulb so much that gas comes out of the carb. Wait a few hours then try starting for a while with no choke, looking for any sign of a start, keep going and it will get better and start.
scully
Is the fuel  tank vent open ? I can't recall if the cap is an auto-vent or not . Welcome to the forum . I'm sure this will be an easy fix . Don't forget the WM tech. line
I bleed orange  .
1Cross1WayLT15
ALL, thanks so much for the welcome and the possible checks!! It's Monday and back to work. I'll go through these checks in the next couple days.
FYI it's a WM LT15 Kohler 19hp. Here is my initial set up.
Rookie -
1Cross1WayLT15
Gas tank does have a red nozzle ...looks like a shut on and off valve. However it does not say which way is on or off! I've tried both positions.
Rookie -
1Cross1WayLT15
Thecfarm... Milling for a couple chicken coops, WM shed to protect it and a large add on to my barn.
Rookie -
sparks
The red knob needs to be aiming up for it to be open. If it still will not start, remove the hose from the fitting and make it longer so you can put it directly into the fuel tank. If it runs now the shut off is defective. Give us a call.
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
1Cross1WayLT15
Sparks, great!! Thank you!!
Rookie -
Weekend_Sawyer
Good luck and call Woodmizer, they have great tech support.
Jon
Imagine, Me a Tree Farmer.
WV Sawmiller
   Another dumb suggestion is to check the direction of flow on the fuel filter. If reversed that could be stopping the fuel from reaching the carb.
Deese
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
1Cross1WayLT15
Rookie -
