New mill, my first - Woodland Mills HM130
Started by ChugiakTinkerer, August 22, 2016, 03:54:42 PM
ChugiakTinkerer
I'm taking my first steps down the sawdust path, and I truly appreciate the input, advice, and even the unheeded warnings about buying a bandsaw mill.  After flipping and flopping about which way to go, I decided to buy the Woodland Mills HM130.  As much as I tried to justify a Wood-Mizer LT40 with hydraulics, I just couldn't rationalize spending that much when I am ostensibly doing this to save money.  So a hobby-grade mill it is.
I placed my order on the 17th of August and it got shipped on the 18th.  As you can see in the tracking information below the package weighs 1154 lbs.  My mill has toured the midwest and is enroute to its port of departure, probably Bellingham, WA.
I had originally looked at the Woodland Mills 722 for my first mill.  It is limited to a 22" diameter log and only has a 6.5 hp motor.  One consistent message I got from FF was to buy the biggest mill I could afford.  I selected the HM130 over the HM126 because it comes with a 14 hp motor and has a four-post carriage supporting the sawhead.  It has a 3-inch larger throat than the HM126 which may come in handy if I ever get into cutting slabs for furniture.  My package is due to arrive at the port in Anchorage, Alaska on September 1.  I'll need to have a temporary home for it in my back yard to make sure everything is functional and figure out my work flow requirements.  Then this winter I will haul it out to our remote property where it will help build a cabin in the woods.  That thread is here at CountryPlans forum: http://countryplans.com/smf/index.php?topic=14235.0
I have also ordered a box of 4* blades from Kasco based on their recommendation as the best for cutting frozen spruce.  That should ship today and will likely arrive before the mill.  Next on my to-acquire list is a couple of cant hooks and some logs.  I'll probably fell some cottonwood trees in my back yard, but if I opt not to do that this year then I'll have to go cut some on state land.  I can cut firewood trees for a nominal fee, but the state won't let me have anything over 10" d.b.h. without paying extra for it.  They charge 25 cents per linear foot up to 6" diameter, so I figure the trees I am targeting will probably cost $9 to $12 each, $15 if I'm lucky.  Based on some brazen assumptions about tree size, that puts me at around $0.10 per board-foot for the smaller trees and $0.02 per board-foot for a sprucezilla tree.
I will follow up this posting with pics and first impressions when the mill arrives.  Hopefully I'll be making sawdust within two weeks!  8)
ozarkgem
ChugiakTinkerer
Quote from: ozarkgem on August 22, 2016, 04:20:22 PM
must be some tall trees
I'm sure the actual trees will not measure up to my expectations.  But we'll see.  I know there are plenty of spruce in the area of my property that are bigger than my reference tree.  That was a spruce I felled in my back yard a few years ago.  I don't know what it's exact measurements were, but it was probably 12" d.b.h.  I do know that from ground to tip it was 48' as I had to drop it in a pretty tight spot.  According to some, white spruce can normally grow up to 98 ft (http://en.wikipedia.org/wiki/Picea_glauca).
I'm guessing as to how much the state would charge me for the same tree, as I don't know where the 6" diameter threshold is.  So 36' seems a reasonable guess.  For the board feet calc, I was using International scale with the FF Toolbox calculator.  I may have been naive in thinking I can get two 16' logs out of the same tree, but at least I've got a starting point.  If it's only 1.5 logs then I'll either be looking for bigger trees or paying a bit more for standing timber.
Here's some background on white spruce harvesting from this article: http://www.alaskajournal.com/business-and-finance/2012-11-09/dry-creek-sawmill-customers-reach-delta-lebanon
Quote
A typical white spruce is about 85 feet tall with the tree tapering at the top. About two-thirds of the three, typically about 50 feet, can be used as a log for home building or lumber. The remaining third can be used for other things, like fuel.
ozarkgem
the good thing about owning the mill is you can cut any length you want. I cut 4' logs just for my pallets. Usually pieces left over where I buck them up.You will have short stuff in the cabin and can cut the logs accordingly. You are going to have a blast.
starmac
Don't know how well you know Tom and his Brad at dry creek, but those guys sure have it going on and are great guys to do business with.
clintnelms
Congratulations! You're going to love it. I love my HM126. Really like some of the upgrades on the HM130. Especially the adjustable blade guide. I believe that will make a big difference.
btulloh
Congrats on the new mill and good luck with your quest.  I bet we'll see you on one of those many Alaska shows on Discovery Channel, etc.  ;)
I've had the HM126 for about a year and have been well pleased.  The HM130 looks well worth the extra bucks and it looks like it's been improved quite a bit.  I think it'll treat you right.
Working out the kinks is a great idea before taking it out to the wilds.  I had a few little issues in the first few months that were taken care of quickly and happily by the folks at Woodland Mills.  They are good on customer service, but that gets tougher when you're off the grid.
You'll probably want to get a good spares kit together while you're working out the kinks.  Besides the usual belts and bearings, an assortment of small hardware wood be good,  There are some small screws and bolts that like to come loose (Loctite?) and jump into the sawdust.  No big deal, as long as there's a hardware store nearby,
One thing that failed on mine was the nipple that feeds lube into the ball valve,  Broke right off, as it is also used the mount the valve.  The original was quite thin and couldn't take the strain of turning the valve constantly,  It may have already been improved.  I just replaced it with a fitting from the hardware store that is more robust.  For me, that was a 15 minute round trip.
It's hard to anticipate every failure but they will happen.  Maybe some other Woodland owners can chip in with some spares suggestions.
Enjoy your sawdust and good luck.
Bob T
HM126
btulloh
Nice thread on your build.  Thanks for posting the link.  I plan to poke around and see what other people have posted when I get a chance.
HM126
ChugiakTinkerer
@starmac, I don't know the guys at Dry Creek at all, it was just a handy article providing a little info on my target tree species.
For everyone else, thanks for the pointers on running a Woodlands mill.  My intent is to post as much info and pictures as you all can tolerate to give some user perspective on the HM130.  Being a new product there isn't much information out there.  You all have done a great job pointing out the strengths and weaknesses of the HM126 and I hope to return the favor with the HM130.
ChugiakTinkerer
My shipment of blades arrived from Kasco yesterday.  It looks like my mill arrived at the port terminal yesterday too.  Hopefully it's loaded and sails today for Alaska.
I'm scheduled to have an arborist swing by tomorrow evening and give me a quote on dropping my four cottonwood trees.  Not exactly prime wood but probably good material to learn on.
Dan R
Just started reading this thread and noticed the talk of the WM 130 and the talk of adjustable blade guides. I have purchased the Cooks guides for my WM 126  but have yet to install them. Could someone post a picture of the guides. I think I have a good way to mount them on My 126 but might find a better way. Thanks in advance Dan
ChugiakTinkerer
Dan R, happy to oblige once I have my mill set up.  I got a call from the shipping company today that it arrived, so will pick it up tomorrow.
fishfighter
Quote from: Dan R on August 31, 2016, 10:54:23 PM
When you do swap over, please post some pictures.
Bill Ragosta
I'm really excited to find this thread.  I've never owned any mill and I'm considering buying a "hobby mill", but I'd like it to be heavy duty enough that I want be disappointed when my logs are too large for the mill or the mill is too wimpy to handle the job.  I found the Woodland Mills HM130 and have seen quite a few of the company's marketing videos and so far it looks pretty good.  I'll be anxious to see follow up threads here regarding any problems you may have or completely positive reviews.
Welcome to the Forestry Forum, Bill Ragosta.  There are many satisfied Woodland Mills owners here.
goose63
Hi Bill
I have the Woodland 126 and put some big logs on it
Some times thy need a little triming with a chain saw but that mill will cut it 8)
goose
thank you to all the vets
scmilling
Hi there. Good luck and enjoy the milling with your hm 130.
I've just put the deposit down on a hm126 to work alongside and complement my lucas 10" swinger. Its only a year old and very lightly used. Both mills seem to get excellent reviews for quality and value.
Currently I either reject jobs or logs within a job for being too light to keep in place with the lucas, or I simply can't process them in an efficient and time sparing way for the client. I should be able to fix the track of the hm permanently in place hard to one side of the same trailer I use for hauling the lucas .Dogging short and light logs has always been an issue with the lucas, which I can now keep for the high production logs.
I'll let you know how it works out.
Shaun
-Think I need a bigger hammer !
InTheHills
ChugiakTinkerer - Have you had the chance to setup the mill and get an overall feeling for it?
ChugiakTinkerer
Quote from: InTheHills on September 24, 2016, 08:59:02 AM
Time being in short supply, I have been trying to get my other chores done before I really start on the mill.  I have assembled it but still need to fire up the motor.  Assembly is pretty straightforward, although as mentioned in some HM126 posts the manual is sketchy on details.  Even though there is no fuel or oil in the engine yet, I've been rolling the saw head up and down the rails just to enjoy the feel of it*.  It is stoutly made.  I don't have anything to compare to but it certainly does NOT feel cheaply made.
The sawhead is massive.  I don't have a FEL or forklift, so getting the sawhead up on the tracks was a trick.  The thing weighs over 400 lbs, maybe more like 500 lbs.  We ended up tilting it back and forth, each time shimming the front or back up with a 2x4.  Eventually got it level with the track and rolled it on.  I'm giving more and more thought to building a trailer for the mill.
With shipping and assembly so far I have noticed only one negative thing.  One of the latches that secures the blade guard cover was damaged.  I'll get in touch with Woodland Mills about it, but I plan on at least getting the mill fully operational before I make the call.  Hope to get some pics of it cutting cottonwood logs later this weekend.
*My wife swears I am making motorboat sounds with my mouth as I am moving the sawhead.  I can neither confirm nor deny this allegation.
clintnelms
Quote from: ChugiakTinkerer on September 24, 2016, 11:51:07 AM
They must have changed the cover to the style that's on the HM130. Mine doesn't have latches. It has the one hand bolt that goes through the top to secure it.
ChugiakTinkerer
Finally got the mill up and running.  Wow, this is a heck of a lot of fun.   8) :D 8) :D
Here's what I'm sawing.  Had a tree feller come in with his boom truck and take down some black cottonwoods that were growing uncomfortably large this close to the house.
Here's my first log.  I think it was about 13" diameter at big end, it ran 10' and was just within the limits of the track.
And here's my first cut.  Using the factory blade, I feel no resistance when the blade enters the log.  The only time I had to push was when I came to knots.
My first slab cut was way too thick.  I should have backed off and made two cuts, would have got a nice board for edging.  As it is, I got seven 1x8x10' and three 1x4x10' which totals 56 bf.  Using 13" the board scales out to 72 bf.  I'll be sure to take diameter measurements at both ends next time, to put in my log diary (log log?).  Now it's time to add the track extension so I can cut the longer logs!
ozarkgem
glad you got it up and going. You will have a big lumber stack before long and have it hauled to your new property. Congrats.
ChugiakTinkerer
I managed to get three logs sawn on Sunday: a 10' @ 13" at small end, a 10' @ 14" and a 8' @ 15" butt end log.  My output for the day was 208 board-feet.  My day went like this:
9:30 am -- Yeeha, it's alive!
10:15 am -- First log queued up
10:20 am -- First cut.  It's so beautiful, I swear I am hearing an angelic choir
11:50 am -- First log cut, making stickers and a stacking area.  This is so fun I could do this all day
1:30 pm -- First log stickered.  Looking at next log, I bet that that it will fit on the track.
3:00 pm -- Second log cut, sticker production is lax.
3:30 pm -- I am eyeing the only other log that will fit the track (still need to put on the 6' extension)
3:45 pm -- enlist my sister to help roll the log completely over my stack of logs.  It's only 8' long, how heavy can it be?
3:46 pm -- Oh my, that heavy
4:05 pm -- Got the short log moved from one side of the log pile to the other.  Ready to roll up ramp to the sawmill.  Continued to wish for a FEL or tractor with forks.
4:15 pm -- Got the "short log" up on the sawmill.  Am duly impressed with the Woodchuck Dual peavey.  Not so impressed with myself.  Where's the ibuprofen?
5:50 pm -- Done sawing the "short log".  Severe sticker shortage.  My supplier is falling down on the job.
6:30 pm -- All wood stacked and stickered.  Wow, that 208 bf doesn't look very impressive.  Where's the ibuprofen?
6:50 pm -- Tools put away, work site "cleaned up".  Starting to appreciate the natural beauty of sawdust.
7:00 pm -- Ah, ibuprofen!
7:30 pm -- Showered and respectable.  Ah, bourbon!
A few more days like this and I'll have my cottonwood all stacked and drying.  Hopefully I will regain some of my youthful vigor in the process.  I definitely learned how important it is to organize and manage your work space.  Minimizing the amount of log handling and board handling will be something to improve on.
ozarkgem
I usually deal with everything immediately . I don't just throw the slabs down and then have to pick them up later. I put them in a rack. I edge the boards from the same log. I don't let them pile up. I stack and sticker as they come off the mill. I only want to handle the stuff once.  Just me. Glad you are enjoying it. Now get the list of materials for the cabin and get cutting.
btulloh
Congrats on getting your mill up and going.  You're hooked now.  You'll get a rhythm going after a few logs and everything will get easier.
There's never enough stickers, especially dry ones.
Ibuprofen is your friend.
HM126
fishfighter
Quote from: btulloh on September 28, 2016, 07:05:45 AM
This and a couple Ibuprofen was a must this morning for me. ;D
Timster
One of the first things I did with my new HM130 was to make pallets and stickers. I made over 300 stickers and I think I have used about half of them already.
fishfighter
Yep, a couple thousand more and you are good for a little time. :D I saw some of mine from edging boards. I use my chainsaw to cut to length once I get a stack of them. One thing I really need to do is build a house just for them and also train my dog to fetch them up and put them in said house. :D
Ox
Congrats on your mill!
This might help you for your sticker problem:  When I find a punky(er) tree I'll cut the whole thing into stickers.  This tree wouldn't give me good boards for anything more than simple wall paneling.  I get lots of stickers in short order.  They also dry pretty quickly if they need drying at all.  This is usually due to the tree being a deadstand.  This is red pine so far and no problems.  Good luck and stay safe!
ChugiakTinkerer
Quote from: fishfighter on September 29, 2016, 06:20:41 AM
Good idea.  I'll work on training the dog, but right now I think he's a lot better at training us!   ::)
Thanks all for the comments and encouragement.  Looking forward to more milling time this weekend.
ChugiakTinkerer
Had a little time this weekend to work on the mill.  I got the 6' extension put on, but it came missing a couple parts.  The extension came on a separate pallet from the mill and the cardboard box suffered some shipping damage.  Nothing critical that prevented me from installing it, as I was able to get some bolts at the hardware store.  But I am missing the threaded tee for the two backstops.
I put my biggest log on the mill yesterday.  Definitely did not have a good rhythm, as a couple times I caught myself at the end of a cut going to turn off the water valve but I hadn't turned it on.  Blade was running hot which added to the dulling.  The logdog I nicked last week didn't help.  Soon after I was getting a wavy cut, so I opted to replace the blade.  There wasn't too much blood spilled when I opened the box of Kasco blades.  It was a good thing going through the blade replacement because it helped me realize I had done a poor job on blade tracking and tension.  After re-reading the manual and doing it right this time, the Kasco blade was ripping through the cottonwood.
The blade was cutting so well I even tried to cut through a backstop.  Whoops!  Second blade replacement went much quicker, and I learned to wear gloves while changing blades.  Negative reinforcement can be very useful!  Got the sawing completed just as family was coming over for dinner.  My dad is impressed with how awesome a bandsaw mill is, and my mom thinks I'm crazy wanting to cut all the lumber needed to build my cabin.
goose63
Tinkerer i got some extra t handles if ya need them pm me
goose
clintnelms
I've hit the backstop twice in the last year. You'd think I would have learned my lesson the first time, but after the second time I did figure out that the little L shaped bar hanging down is designed to stop that. You just have to make sure it's turned so that it hits the backstop first before the blade. I assume the HM130 has the same thing.
ozarkgem
sawing into the back stop is a given. I hit mine a while back, I was thinking hey I haven't hit my back stop in yrs, 2 min later I hit it. I was impressed how far the blade cut into it.
ChugiakTinkerer
Quote from: clintnelms on October 03, 2016, 04:45:28 PM
Yep, it does.  It works best when you turn it back down after changing the blade.
smiley_furious3
ChugiakTinkerer
Quote from: goose63 on October 03, 2016, 04:38:13 PM
Thanks Goose, I may take you up on that if Woodland Mills doesn't deliver, but I'm optimistic they will fix it.
DannyLand
I hit my backstop once by just 1/8" from the top, frustrated that the bar designed to prevent this wasnt long enough to actually reach the bottom of the blade height.  Maybe mine was a screwup but it was 1/4" shy of the blade so if the stop was up 1/2 an inch above the blade height, it worked fine, any lower and I wasnt so lucky.   I made my own out of 3/8 steel rod but made it longer, worked great, until I clipped the top of the log clamp and killed a brand new blade.  Ive learned to not trust having it and just use my eyes or wooden stops when Im not pushing against it hard.
    One other thing I didnt like about my WM saw is the thin wall tube used for the log stops to socket into.   One heavy log rolling into the stops is all it took to bend them out of square to the deck.  After that, I had to shim them to 90 degrees for accurate square cuts.   Since then I have welded up new tracks using heavier wall tube and dont have to worry about it anymore.  Im going to weld additional sockets on the clamp side to help prevent the log from rolling off the mill when Im loading it with the skid steer or trying to flip it when squaring up.  Its happened more than once and pinned a leg when the peavey slipped while I was adjusting the clamp.   Thankfully that was just a 14" log 8' long.
Woodland Mills HM126, Hudson debarker, Jonsered 2171, New Holland skid steer, 1955 International Harvester Dump 132
fishfighter
OP, so you meet your metal. :D Just another battle scare. :D
tareece
Quote from: DannyLand on October 03, 2016, 07:29:57 PM
Pictures mahhhn
Todd Reece
Lover of many things. Experienced in most... expert in few
ChugiakTinkerer
Quote from: tareece on October 07, 2016, 05:35:27 PM
Pictures mahhhn
Maybe put details in the sawmill mods thread?
https://forestryforum.com/board/index.php/topic,7789.0.html
Mcgeezer
I'm really interested in this mill.  The Trekker xl is what I have my heart set on.
I'd love to hear feedback since the last posts or others with experience on this mill. I find the comments about value, performance, customer service very positive about WM
PC-Urban-Sawyer
Quote from: Mcgeezer on November 26, 2017, 02:41:35 PM
Gets kind of confusing when you refer to a mill as a WM, since Wood Mizer has been making, selling and supporting their mills for several decades and most people think of Wood Mizer when they see WM...
