Brought some big ones back today
Started by scsmith42, August 20, 2016, 08:40:05 PM
scsmith42
A pair of 60 footers and a 48 footer.  Small end diameters at 50' is 24" on two of them and 26" on the third.  Big end diameters of 36" - 40".  They neck down a bit from 50' - 60'.
You can't see it in the photo, but there is a forklift supporting the small end of the logs in addition to the track hoe picking up the large end.
My plan is to mill some 58' long siding boards from the outer portions, and some 4" x 18" x 50' beams from the rest.  I should be able to yield 4 beams per 60' log that I'll use to build some 50' parallel chord trusses for the new sawmill building.
Ought to be a fun project!
Tom's 3638D Baker band mill
Dave Shepard
You are really setting the bar high now. Might be a while before I can catch up. :D
YellowHammer
Very ambitious.  This is going to be fun to watch and learn.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
submarinesailor
Scott,
Wish I had the time to come down and help you do the timbers/beams.  Also with the build.  But my "RETIREMENT HONEY DO LIST" is HUGH in so many ways.
Bruce
tule peak timber
Brad_bb
Do you already have a use for the 4x18 timbers?  For long tie beams in a timber frame, you'd want probably 8x14 or 8x16 boxed heart.  Not easy to get that long and quality beam.  A conventional timberframe is typically 36-38 feet at the widest.  wider than that, you have to start doing some serious engineering.
red
My money is on Scott because he is a serious engineer . He is building 50 ft parrallel chord trusses. And of course Having Fun .
5quarter
I don't even know what the Heck a blahblahblah truss is...but I sure like those logs!
Blue Harbor Refinishing
Kbeitz
Quote from: 5quarter on August 21, 2016, 01:35:54 AM
It's what ypu make bridges out of...
Love machine shop work
and Wood work shop work
And now a saw mill work
customsawyer
Nice looking logs. That should keep you out of trouble for a little bit.
www.thecustomsawyer.com
caveman
DanG, those are some serious sticks, loblolly?  I hope that you take pictures to share of the sawing and the eventual construction of your building.
Caveman
tnaz
Quote from: caveman on August 21, 2016, 06:16:59 AM
X2 From start to finish.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Satamax
kelLOGg
Scott, where did they come from? Where ever, nice find :o
Bob
scsmith42
Quote from: submarinesailor on August 20, 2016, 10:34:23 PM
Scott,
Bruce
I wish you had time too!  It's funny how it seems as if once you retire you have less time than before!
scsmith42
Quote from: Dave Shepard on August 20, 2016, 08:45:48 PM
Lol!  :D
scsmith42
Quote from: Brad_bb on August 20, 2016, 10:46:23 PM
Brad, thanks for the advice and insight.
Yes, I already have a use for them, although I may consider some different dimensions.  What I'm building with the fifty footers is similar to this style of truss, except that all of the dimensions are different:
I'm also building some 40 footers from some different material.  They will have three lengths of top and bottom chords apiece and two sets of inner members.
5quarter
Quote from: Kbeitz on August 21, 2016, 02:57:46 AM
ahhh...I see. I'm familiar with those but call them a truss beams. I don't speak engineering very well.  ;)
scsmith42
Quote from: customsawyer on August 21, 2016, 05:26:17 AM
Maybe for a week or two...  :D
scsmith42
Quote from: kelLOGg on August 21, 2016, 08:37:26 AM
Bob
Duke University.  They had to remove them for a dormitory project.  Duke has been great to work with about treecycling.
47sawdust
Ahhh,Blue Devil pine,hope no Tar Heels got near it  :D :D
Mick
scsmith42
Brucer
Quote from: scsmith42 on August 20, 2016, 08:40:05 PM
... My plan is to mill some 58' long siding boards from the outer portions ...
Having cut a few 1x8 x 36' siding boards, all I can say is -- handling them is an "interesting" experience ;D.
Bruce    LT40HDG28 bandsaw
scsmith42
Quote from: Brucer on August 25, 2016, 12:33:47 AM
lol, I know, as is installing them!   :D  I've worked with 40 footers before.
