what is wrong with this picture?
Started by moosehunter, August 19, 2016, 05:45:01 AM
moosehunter
That log is way to big for my mill!
Thank you Forestry Forum knowledge base. Started with 18" diameter small end x 26'. Finished 8" x 16" x 26'. First of 13 that are too long for the mill. This is the heaviest though.
Higher than my expectations
lshobie
Did you pull the blade out of the log and then reposition and cut off the rest?  We just did a bunch like that.
Looks great!
John Deere 440 Skidder, C5 Treefarmer,  Metavic Forwarder, Massey 2500 Forklift, Hyundai HL730 Wheel Loader, Woodmizer LT40, Valley Edger,  Alaskan Mill, Huskys, Stihls, and echos.
YellowHammer
Ain't nothing wrong with that picture! Good job
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Rougespear
Care to comment on "how-to" of the milling process?
Custom built Cook's-style hydraulic bandmill.
123maxbars
Sawyer/Woodworker/Timber Harvester
Woodmizer LT70 Super Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
LeeB
Quote from: Rougespear on August 19, 2016, 10:28:04 AM
Try here. https://forestryforum.com/cgi-bin/tips/tips.cgi?display:1061208316-32360.txt
You can find this a whole treasure trove of other stuff in the extra link ( https://forestryforum.com/board/index.php ) located at the top of page. ;)
Carson-saws
 moosehunter...now THATS determination Sir.  Great job!
Let the Forest be salvation long before it needs to be
submarinesailor
Percy
red
That log makes your sawmill look skinny . . . Great  Job  !
rl
 it was obvious real quick what was wrong with that picture, but you won, good job  I've done two 35 ft' on my twenty one ft mill  had to support end of log with tractor bucket   getting two sides flat is alot of work but hard to find 35 feet 8x8 anywhere else
rl
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
killamplanes
Ever thought of getting into sawing crane mat logs.. :D :D
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
Brucer
I tried sawing like that a couple of times, but it was a pain. So I got smart and added a 6' extension.
Then I found myself sawing like that again, so I got even smarter and added another 6' extension.
And wouldn't you know, it started to happen again ::). DanG! I give up.
2 - 8x12x36' timbers on a 33' mill.
Bruce    LT40HDG28 bandsaw
customsawyer
I don't think you can ever have a mill long enough. They always seem to want longer than your mill. Good job on getting it done.
www.thecustomsawyer.com
