Comstock Logging
Author Topic: Campfire chimmey  (Read 3857 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Campfire chimmey
« on: August 15, 2016, 12:08:12 pm »
Just got it done. It sure helps to keep the smoke away from the people
around a campfire... It was a salt spreader.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline Kbeitz
    • My Hobbies
Re: Campfire chimmey
« Reply #1 on: August 15, 2016, 01:53:26 pm »
Opps... I think I stuck this in the wrong spot...
I thought I put in the general board...
Sorry...
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline red
  • we will never forget
« Reply #2 on: August 15, 2016, 02:16:05 pm »
In todays Heat it can be a solar chimney, thermal chimney or  solar updraft tower
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline Kbeitz
    • My Hobbies
« Reply #3 on: August 16, 2016, 08:59:42 am »
Finished...
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline OneWithWood
  • I am happy!
    • elmhouseindiana.com
« Reply #4 on: August 16, 2016, 01:45:24 pm »
Did you have an aha! moment at the pig roast?
One With Wood
www.elmhouseindiana.com
Online Jeff
  • Lead Administrator and Founder
  • This rule uses my position.
    • THEE Forestry Forum
« Reply #5 on: August 16, 2016, 02:04:14 pm »
Not a forum pigroast. He's not been to one yet.
For the life of me, I don't know how that is supposed to work unless you get rid of the legs.
Offline Texas Ranger
  • Texan, by God and by choice.
    • Staples Forestry
« Reply #6 on: August 16, 2016, 02:46:41 pm »
Convection currents, that accelerate going from the big funnel to the small pipe, creating a draft.
Offline Den Socling
  • just wondering
    • PC Specialties
« Reply #7 on: August 16, 2016, 03:53:30 pm »
Yeah I think it would work if you could get the current flowing. I read somewhere that smoke around a fire seems to follow you because of rising warm air from your body that draws it in.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #8 on: August 16, 2016, 04:06:16 pm »
When I was taught to start a fire in a fireplace, I was told to hold a piece of rolled up newspaper lit up the flue to get the draft started.
You may have to do that.
Jim Rogers
Offline Gary_C
  • Sunrise on the Prairie
« Reply #9 on: August 16, 2016, 04:13:49 pm »
I doubt that pipe is large enough to draw much air through. Might have to put a chimney section on to get much draft, or a forced draft fan.  ::)
Online Jeff
« Reply #10 on: August 16, 2016, 04:18:10 pm »
Those are all enclosed area scenarios. Seems any breeze is still going to blow smoke in people's faces with 6 feet of open air above and everything  around it.
Offline elk42
« Reply #11 on: August 16, 2016, 04:23:55 pm »
  Will not work pipe to small and needs to be closer to fire pit and at least a12"x 12"
 flue.
Machinist Retired, Lt15 WM 25 HP, Stihl 044, Stihl 311, Kubota M2900w/FEL, KUBOTA L4800 w/FEL,
Lincoln Ranger 10,000, stihl 034,
Offline Kbeitz
    • My Hobbies
« Reply #12 on: August 16, 2016, 04:31:42 pm »
I did what I wanted it to do. we are in a tight valley so we dont get much wind.
The smoke does go up the pipe no problem. The biggest reason I made it was
to protect the trees over head and it's doing just that. I'm sure if we get some
wind I will have problems but I dont like burnning when the wind blowing anyway.
I will try to get a picture next fire.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline cliffreaves
  • Finally figuring things out.
« Reply #13 on: August 16, 2016, 07:32:00 pm »
I was always told smoke follows beauty, so I usually just sit next to my brother.   Together we create a sort of vortex that pushes smoke away in a very rapid rate.😂
Online Al_Smith
« Reply #14 on: August 16, 2016, 07:36:43 pm »
Ah yes.white man build big fire,stay far away .Indian build little fire sit up close.< little big man ,movie.
Offline Kbeitz
    • My Hobbies
« Reply #15 on: August 20, 2016, 12:59:52 pm »
I got some rocks put around it today...
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
    • Staples Forestry
« Reply #16 on: August 20, 2016, 03:52:52 pm »
Venturi effect.
Online 21incher
« Reply #17 on: August 20, 2016, 06:31:06 pm »
Last place I lived I had to put a hood like that above my fire pit and wrap some hardware cloth wire around it after having a couple of parties around the campfire that a grumpy neighbor a couple of houses down called the police on me. Turned out open campfires were not allowed, but being enclosed it was perfectly legal. I had the local fire department inspect it and notify the police to leave me alone.  :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline Den Socling
  • just wondering
    • PC Specialties
« Reply #18 on: August 20, 2016, 07:13:12 pm »
Sure glad I don't have stupid neighbors like that,  >:(
Offline red
« Reply #19 on: August 20, 2016, 07:17:05 pm »
That's awesome I can't see the smoke at all
