Husky 365 vs. 372xp
Started by gman98, August 14, 2016, 09:24:50 PM
gman98
Hello guys.  I'm looking at getting another saw to have as a back up and I can't decide what I want.  I'm trying to decide between a husky 365 and a husky 372xp.  They seem to be a similiar saw with the only difference being the price.  My main use will be cutting firewood for the house, possibly cutting firewood commercially or logging next summer, cutting/building around camp, and clearing out grown up roads.  What one would you guys pick out of those saws for what I'm looking to do?
Forest technician and part time equipment operator.  Looking to get set up with some logging equipment of my own.
weimedog
Either one will do the trick. Same top end....just the 365 has different top covers, smaller air filter, and a transfer port "cap" with a "fin" to cut the power a bit. Same cases. Same crank. Same cylinder. Same piston. Same ignition....get the point?
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
DelawhereJoe
I'd personally go with the 372xp over the 365, I think I remember the 365 at 4.8 hp and the 372xp at 5.5hp. More power is always better when the saws weigh the same.
weimedog
All true.... an afternoon of elbow grease can narrow the difference. ..but that is time and risk. For many probably most it's worth the extra money to have it from the factory.
Ada Shaker
If I were to be looking at making a quid from my saws, always go for the better/reliable saw. If I were just looking for home use, I would factor in price for a backup saw, that may not see a lot of use.
If it hangs to the left, your likely to be a Husqvarna man.
If it hangs to the right, your likely to be a Stihl man.
Anything else is an uncomfortable compromise.
                             AND
Walking with one foot on either side of a barbed wire fence can become extremely uncomfortable at times.
XP_Slinger
They are both excellent saws with identical build quality.  I have a 372XP and while there is a power difference between the two, my friends 2166 (jonsered twin to the 365) is a strong saw with excellent low end torque.  In stock configuration, the 365 won't let you down.  After your warranty runs out in 2 years you can get rid of the restrictors on the transfer covers and BAM! You've got yourself a 372XP.  It's really that simple.  Had I known about that trick when I bought my 372 I could've saved myself $150.
    Here's a video of my friends stock 2166, saw isn't broken in yet, 20" bar, full comp chain.
http://youtu.be/9hzT4DBqVqg
346XP/NE
357XP...ported by MeDremel
372XP/XT...ported by A. Burr
Homelite (Solo) 340
I'd rather be in the woods than on this computer.
danbuendgen
I would go with the 372. I have owned both, and they weigh the same, but they 372 has more power and low end torque. $150 is not that much difference for what you get.
Husqvarna ~ TimberJack ~ Dodge Cummins
DelawhereJoe
For around $40 more why not get a 576xp? Even more hp....
SawTroll
Quote from: weimedog on August 15, 2016, 06:19:39 AM
Yes - but the low air filter/cover of the 365 is preferable except in very dusty conditions.
We are of course discussing the x-Torq versions of both models - the top end differences of the original versions weren't similar to what's described here.
Information collector.
OH logger
Quote from: XP_Slinger on August 15, 2016, 10:02:08 AM
man you guys sure do cut short firewood!! :D
john
XP_Slinger
Quote from: OH logger on August 15, 2016, 08:48:19 PM
Ha ha ha!  Takes about 7 hours to cut 1 face cord...lol!
346XP/NE
Homelite (Solo) 340
HolmenTree
joe_indi
The 365 has a Zama carb and the 372 a Walbro.
I would go with the Walbro
SawTroll
Quote from: joe_indi on August 16, 2016, 12:56:58 PM
That's about the original versions, not the current x-torq (XT) saws. The XT models both have the 19.05mm Walbro RWJ-4.
Grandpa
SawTroll, may I ask why you prefer the low 365 filter and cover?
630red
i have customers that have both models and when the 365 needed piston cylinder replaced i put the 372 top end on they said it was better then they original 372,dont really think it was ,mind over matter me thinks ;D
SawTroll
Quote from: Grandpa on August 16, 2016, 06:57:18 PM
The saw is neater and better looking with the low filter/cover, and it is standard over here.
HolmenTree
I'll answer for SawTroll.  Low top cover is so much nicer for ergonomic handling . Felling and limbing  in thick under growth around the trees for example. Compactness is something I like in a saw.
Here we have a saw with air injection that cuts down periodic cleaning greatly.....and it's got a oversized airfilter that it doesn't need.
Only application I can see for that big air  filter is cutting dusty red cedar on the west coast.
HolmenTree
Niko you read my mind and beat me by 1 minute answering  a 2 week  old post  :D
HiTech
I believe I would go with the 372 XP. It's rated at 9,600 rpm's. The 365 is rated at 9,000 rpm's. I have a 1995 365 and that saw was rated at 9,300 rpm's, very close to an XP saw. For faster cutting the XP's are hard to beat.
Grandpa
Saw Troll and Holmen Tree, thanks for your response.
SawTroll
Quote from: HolmenTree on September 01, 2016, 09:46:16 PM
;D - but you described the difference better.
In most conditions the HD set-up just is in the way, and from the factory it just is an option. Imo it was a mistake to make it a more or less standard feature in the US (not sure how it is in Canada).
SawTroll
Quote from: HiTech on September 02, 2016, 06:06:02 AM
That's just the nominal max power rpms, they actually vary a bit with each individual saw. Max recommended rpm is of course much higher - but often is left out of the specs these days.
ehp
in the new 365/372 xt line up the cylinder on both saws is the same , the piston is the same , the only difference is the door on the 365 has a blocker to cut the amount of air that moves threw the transfer port and the 372 door is smooth . grind the blocker off the 365 door and you got a 372
