is the heat stopping anyone else ?
Started by SCSawyer, July 08, 2016, 04:51:58 PM
SCSawyer
Well I got off work early today and was planning on sawing , got home and the weather station in my yard says 100deg, needless to say I'm sitting in the recliner until the sun gets behind the mountain.
Silas S. Roberts , Bluff Mtn. Timber
Ox
We haven't gotten that hot up here, *only* in the 90s.  It stops me every day.  Can't take the heat so I stay outta the kitchen.  High humidity as well so I only get a little time in the morning and that's it.  To heck with all of it.
fishfighter
I get out at the break of daylight and call it a day by 9am most days. :(  98F with a heat index of 107F today.
I am scheduled to get back to sawing Monday.  I ain't looking forward to it.   smiley_sweat_drop smiley_thumbsdown smiley_sun
Nomad
Me too.  The weather we've got down here right now, half a day is it for me, MAX!
WoodMizer LT50HDD51-WR
Lucas DSM23-19
lshobie
we can only get about 1600bf in about 6 hrs, too hot.......time is tight!!
https://www.youtube.com/watch?v=Mz95hJqOXyY
John Deere 440 Skidder, C5 Treefarmer,  Metavic Forwarder, Massey 2500 Forklift, Hyundai HL730 Wheel Loader, Woodmizer LT40, Valley Edger,  Alaskan Mill, Huskys, Stihls, and echos.
chevytaHOE5674
What's this "heat" that you all speak of. High temp today barely hit 60°F, with a cool north wind. Had long sleeves on and had the heat on in the tractor cab.....
gww
I was building a 20x48 foot machine shed and got the roof on two days before it went to the 90+degree mark.  I have not did one thing since then.  Have not even picked up the board ends that I have left over and that are in a pile on the ground.  I am talking lazyboy time.  I used to get up at 5 am.  I am getting up at seven and it is all ready steamy by then.  I have started out side and picked maby one board up and said heck with this.
The shed still needs 3 walls if I go that far and I am waiting for my next big spert of energy.  Till then I am blaming the heat.
Cheers
gww
paul case
Not stopped.
Hours changed to 6 to 12:30 and we are under a roof with fans going. By noon we are ready to throw in our sweat drenched towel!
PC
pc
SCSawyer
I have got to get a ton off stuff done before the seasons change, I need a 16x40 hay shed, a 10x30 primate barn and I need to get a 16x40 sawmill shed all, sawn out and put up by myself before winter, ughhhhhhhhhhhhhhh
carykong
Yup
It's hot here,too
Stabbed 4 sides to nice
Yellow pine log today and then called it a day
Brucer
What's heat? :D
We had our hot spell last month -- 4 weeks earlier than any other year. Then it got cold again. I've had to light a fire in  the wood stove the last 3 mornings to take the chill off ::).
Bruce    LT40HDG28 bandsaw
It has been awful hot here.  I can make it to early or mid-afternoon, but slowly.  Yesterday it was 100 degrees.
At 7:00 a.m. it is 80 degrees with 79% humidity.  Going to be a real rough one today.  Without the sawshed and fans, I would be toast.
fishfighter
Was sitting on the patio this morning drinking my coffee as I do every morning. So DanG hot already, I think I will do nothing today. :( DanG pool water is so hot that one can't swim in it. >:( Going to drain off some and add fresh cool water.
sawwood
Yep to hot here and JR and I with past heart trouble we have not been sawing any. I was been
in the high 90's with high due point. The only thing that's the heat is good for is the solar kiln.
Its been at 140 degs most day so the oak and ash will be done soon. Sure would like the cooler
weather as we have three more logs we need to mill be for JR goes to Texas for the winter.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Chuck White
I won't be sawing until the heat index changes a few degrees!   smiley_sweat_drop   smiley_sun
opticsguy
North of Seattle, I am cold this morning, 58 degrees.  Should be about almost 70 by end of the day, cant find any excuse not to be working....... but I will find one.......
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
kelLOGg
I'm going to the mill to do maintenance but not to saw until Monday when we get into the low 90s. The RH is stifling.
Bob
Solomon
I'm on the coast of  Virginia ,  it's been in the mid 90's here.
I have a lot of customers calling and I'm telling them  "When the weather cools off",     I'm just not milling in this heat,  I'm  55  not  25 years old.  Can't run with the young Bucks any more.
  I'm not as good as I once was, but I'm as good once as I ever was.
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
Sixacresand
I do a couple hours in the morning if I can start soon enough.  And another couple hours after supper if it's not lightning and raining.  Milling is definitely not a Summer Sport.
Percy
Quote from: Brucer on July 09, 2016, 12:29:22 AM
What's heat? :D
Been the same up here. The odd nice day but generally cold as a bankers heart.
ellmoe
fishfighter
Against my better judgment, I went out and did some work on the camp. Like to black out. Having all kinds of body cramps. :( Done hit the vinegar twice and no help. :(
SCSawyer
Glad to see I'm not the only one.  Its been upper 90's , I'm just not doing it
BigZ La
Quote from: fishfighter on July 09, 2016, 01:55:44 PM
I use Potassium Gluconate for muscle cramps It works as soon as I take it.
