Crown
Started by kenfrommaine, July 05, 2016, 10:18:26 PM
kenfrommaine
Hi
My band wheels are steel 20" x 1.5" how much crown should be put on them? Or is i use bands do they come with a crown?
Ken from Maine
boscojmb
I run crowned wheels.
The crown on my wheels in very slight. From eyeballing it, it looks like about .005"
Are you running 1.5" bands or 1.5" band wheels.
I'm running 1.5" bands so my wheels are 1" or less.
John B.
Log-Master LM4
Kbeitz
Grizzly tools sold what they call bands saw tires (that was the rubber cover
that went over the steel wheel) They came with the crown.
Love machine shop work
and Wood work shop work
And now a saw mill work
Satamax
Well, for the wheel crown, there is on the internet; a manual for a recrowning grinder. I can't remember the make, or model. I know i downloaded the instructions. But can't seem to find those. Only thing i remember, is them saying peak of the crown on a normal saw should be placed 1/3 to the front, not right in the middle. It's placed in the middle for a "double cut" cutting forward and backwards.
Kbeitz
All the bandsaws I ever worked on all had the crown in the middle
and I worked on a lot of them. I even made a wheel or two.
I'm not sure that it would matter .
4x4American
Interesting...I'm sure that the crown on our belted bandwheels is centered too
Boy, back in my day..
Kbeitz
Google links say the middle...
https://woodgears.ca/bandsaw/crowned_pulleys.html
But i also found this...
A belt or blade will climb to the largest diameter of a pulley.
If the largest diameter is on the edge of the wheel, that is
were the blade will track. On the large sawmill bandsaws with b
lades a foot wide, the wheels are ground flat.
E-bay has "PRE-CROWNED Bandsaw Tires"
kenfrommaine
Thanks for the replies. The wheels are 1.5" wide x 20".
Those band saw tires are pricey,  but look like it would do the trick.
Do you think that a crown could be ground or filed onto the wheels if it only has to be a few thousands, I have time and not lots of cash to put into the mill. Maybe make a jig for a belt grinder or such?
Another question with the 1.5" wide wheels I have can I run 1.25" blades or what size would you recomend?
thanks again
york
No,you can not run 1-1/4 in. Bands on wheels that wide-why not bite the bullet and get 19 in. pulleys and be done with it.....
Albert
Kbeitz
I took a flat belt pulley and made a crowned bandsaw wheel out of it
by holding a side grinder to it while the saw was running.
Worked great.
kenfrommaine
 So what width blade would I have to run on those 1.5" wheels? Have a new (supposed) 18hp for power.
Satamax
Quote from: Kbeitz on July 06, 2016, 06:10:10 PM
Kbeitz, sorry to be picky. But how have you checked? Magnetic base and dial micrometer?  ;D
Quote from: Kbeitz on July 07, 2016, 02:28:22 AM
http://armstrongblue.com/Band_Saw/BarnhartOperatingInstr.htm
Well, i think there is two things at play. You want the blades to track forward, so the teeth clear the edge of the wheel, and they clear enough so that the tension doesn't change the set.
And the other reason behind the 1/3rd crowning is that when you feed the wood, the blade is pushed slightly backwards.  And the forward crown would  pull the blade back against this movement.
This is all theoretical. I'm no expert.
https://www.youtube.com/watch?v=pvjMwBqDQYA
As well, there's something, over here in France, we use a lot of wide bands. Mine are 4 or 5 inches. And they are slightly "tensioned" so the shape of the band matches the crown of the wheel.
Kbeitz
Checked ???
Checked what... How much crown ?   I just eye balled it to make it look like the other wheel
I had... I have a collection of over 50 flat belt pulleys and each one seems to have a different
amount of crown. So I don't think it really matters.
york
Too bad Cooks does not chime in on this,because they re-crown Band wheels.....
Albert
Kbeitz
To really do it right you would need a really big metal lathe.
Czech_Made
Quote from: Kbeitz on July 08, 2016, 07:54:53 AM
Hmm, rotary table maybe?
Kbeitz
Hey... Yea... I got one of those... Never thought of that...
Satamax
Quote from: Czech_Made on July 08, 2016, 10:32:56 AM
Quote from: Kbeitz on July 08, 2016, 11:27:37 AM
Well Kbeitz. Have you ever seen  lathe milling? Throw the dividing table onto the  the chariot after removing the square turret.  And put a big flat mill (bigger than the wheel's rim) in the chuck of the lathe. I even know the trick for turning the crown. Only with flaty mills which have the soldered inserts or screw on inserts which are proud of the base. You use the inside edge of the inserts to machine the wheel. Because the Cutting action of the mill is round, it's tangent at the edge of the rim, and in the center of the rim will be different, because of the shape and size of the flat mill. You most certainly can cut a crown this way. Shim the wheel and dividing table assembly, for the rim to be on center of the chuck, or may be 1/3 off center. As linked above. Tho, to be sure of the end result, a bit of prior thinking, metrology and turning knowlege would be in order
Got it?
Satamax
A bit like on this one.
https://www.youtube.com/watch?v=foLsg3g7toU
Imagine what would happen if there was a wheel in place of the al block. And what would happen if that wheen was turning.
Far easier with small flat mills, to make the wheel's rim concave, but it can also be made convex.
Kbeitz
I have a milling attachment for my Southbend lathe.
I dont use it because i have a Bridgeport.
Satamax
Kbeitz, i don't know those brands. I know the names. That's about it.
You see the advantage of what i was describing. With the rotating table, chuck on top, and the wheel chucked in there, and a flat mill in the chuck of the lathe. Is that you can even remove the tailstock, go at the end of the bed with the cariage; and machine huge wheels without a face lathe. I have a 800mm polish famot from the 60's. Or late 50's. I think i could machine wheels of nearly 2 meters if i realy wanted  ;D Mind you rim width wise, i don't think i could go very far with the chuck on the rotating table. May be 4 inch rim with the wheel directly attached to the rotating table. Mind you, there's simpler ways, a mill with a huge slot table could do as well. The travel on my little rong fu mill is only 370mm or so.
Kbeitz
Well Southbend was one of our best. The name was sold out to Grizzly Tools.
Bridgeport was also one of our best.
http://www.southbendlathe.com/
https://en.wikipedia.org/wiki/Bridgeport_(machine_tool_brand)
Czech_Made
Yeah, milling on lathe is just a substitute for real milling machine.
But every machining job has many different solutions.
