Can't find a hot water filter housing with enough GPM
Started by LegendsCreekFarm, July 05, 2016, 03:26:54 PM
LegendsCreekFarm
I have another question as I am trying to buy everything I need to finish my boiler install.
I can't find a hot water filter that is rated above 160 F, and that has decent flow.  The highest one I saw said it had 8 gpm flow and i don't believe that will be enough for my install.
Does anyone have any details about an appropriate filter housing?
LittleJohn
Have you looked at a Wye-strainer?
Cause in my experience that is all you need, before you install a Heat Exchanger to keep the flakes and stuff out of the plates
LegendsCreekFarm
Wow.  I just looked one up. I believe I have some familiarity with these.  I am looking at this one http://www.supplyhouse.com/Watts-0220075-1-77SI-Cast-Iron-Wye-Strainer-Threaded-5117000-p   I am guessing you open the nut on it and there is a mesh filter inside?  Is that correct?   Does this inhibit flow much?
Thanks!
hedgerow
I run four different flat plate exchanger on my Garn and one on the hot water heater and that is all I run is Y strainers ahead of the inlets. I run my Garn year around to heat my hot water. I usually try to clean all five strainers in the Fall before the big heating season starts. I have run the system nine years and haven't had to clean a heat exchanger yet.
LAZERDAN
Wye strainer is the ticket, but get a brass one.      Lazerdan
r.man
You are correct, the screen is inside and you can put a valve on the small threaded hole to blow debris out. Eventually the screen will clog in a way that requires removal and descaling. While the screen is clean flow will not be overly compromised.
LegendsCreekFarm
Excellent! You guys saved me a ton of $$ and aggravation.  I ordered the wye's last night.  Thank you!
