WM split tapered bushing/drive sheave bolts sheared
Started by 47sawdust, June 12, 2016, 07:38:37 PM
47sawdust
The bolts that attach the bushing to my drive belt sheave sheared right off.The mill is a '97 Lt30.The  bushing and sheave are less than 2 years old.I installed them myself.
What did I do wrong? 100 hours sawing time since installation.
Mick
Kbeitz
Most bushings are keyed to the sheave ...
Are you missing a key?
Love machine shop work
and Wood work shop work
And now a saw mill work
elk42
Kbeitz
I think Browning flange type taper lock bushings are the only one that has a keyway
in the taper fit. T B woods does not.
Machinist Retired, Lt15 WM 25 HP, Stihl 044, Stihl 311, Kubota M2900w/FEL, KUBOTA L4800 w/FEL,
Lincoln Ranger 10,000, stihl 034,
Ga Mtn Man
Sounds like you may not have gotten the bolts tight enough allowing the bushing to slip and shear the bolts off.
derhntr
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
elk42
 47
Be sure that the shaft and taper is very clean of trash sawdust and fretting corrosion if
so file and sand to clean.Use the torque value for the screws and check pulley for wobble
with dial indicator.
47sawdust
The key and the bushing are intact and where they should be.I will pull them this morning.I might be able to get the sheared bolts out of the sheave,get new hardened bolts ,clean everything up as Elk suggested,and put it back together.
Thanks for your help.Mick
Mick
ladylake
Quote from: Ga Mtn Man on June 12, 2016, 09:06:37 PM
  Yes, when tightening those bolts you have to go around several times, there is no key on the taper.  Steve
sealark37
If you have a local Caterpillar dealer, purchase their grade eight bolts.  Assemble as above, then re-torque after an hour's sawing.    Regards, Clark
