Hydraulic cylinder idea
Started by kelLOGg, June 05, 2016, 07:20:34 AM
kelLOGg
I want to replace my log leveling jacks with 2 pairs of hyd cylinders that lift a roller so I can not only level but also slide logs/cants. I want to operate them with a hand operated hydraulic pump to lift the roller. I prefer to use 2 cylinders rather than one so I can do a vertical lift because space is limited. (A single cylinder would have to lift the roller through an arc complicating the mounting.) Anybody done this? Ideas?
Bob
Ox
If you're talking about a log turner/clamp then Pineywoods has a proven design that he's shared with us a while ago.  It's a good thread.
Satamax
I think KelLOGg is talking about a toe board.
kelLOGg
york
Albert
Ox
That's really weird.  Earlier this morning I read it and only saw clamp/turner.  Now I read it and it's obvious it's a toe board he's talking about.  Brain fart, I guess.  :)
DDW_OR
47sawdust
I think the older style WM hyd. mills had a T shaped roller that went straight up.Marty Parsons might be able to help you with that.
Mick
paul case
Quote from: Ox on June 05, 2016, 09:52:42 AM
That's ok. I read through this thing and thought for a minute that Grouch made an index for your brain fart.
PC
pc
Ga Mtn Man
kelLOGg
Quote from: DDW_OR on June 05, 2016, 11:46:20 AM
grouch made an index for that thread
https://forestryforum.com/board/index.php/topic,7789.msg1396274/topicseen.html#msg1396274
Thanks, I found Larry's topic and I do remember it but could have never found it w/o the "index". That was a significant effort that will pay off for many.
I think I will go with the arc path model like Larry's. His is very compact and I actually have more space to put it than he did.
Bob
