Size matters, how big can my LT40 Hydraulic lift?
Started by Scott Sawdust, May 26, 2016, 01:32:18 PM
Scott Sawdust
Hey all, I am new to this business. Just got a 40" dia x 10' ash log here, can my LT40 lift it up for cutting? Looks pretty big compared to the other stuff I have been cutting.
You're sure there are no nails in this log? Trust, but verify.
KirkD
The weight Calc in the toolbox says between 4,100 and 4,500 depending on what type of ash it is. We will have to let the experts on the LT40 weigh in on lift capacity.
Wood-mizer LT40HD-G24 Year 1989
derhntr
I have done 42" 14' white pine that I had to cut groove with chain saw to fit guides. and 36" 12' Red and White oaks. Had to use 2 helpers with cant hooks to keep log from rolling off log lift. But picked them up ok.
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
OlJarhead
derhntr
Sure you can manage to get it up on the sawmill, but then what do you do?  You had better load the butt end to the front so that you can see where your blade guides will be.  You will have to roll it to the left to gain throat space.
Be very careful because you do not want to loose that log over the side.
Turning the log will be a major effort.  It takes time and can be done if your sawmill has a two plane clamp and you can use the turner and clamp together to lift and shift the log.  If it does not, you will probably have to rely on a front end loader or something.
Now that you have your mouth full and the sawmill overloaded, the blade will still only raise to 36" above the bed.  That first cut will be taking a whopping 4" off.  You will then have to turn it 1/8th and take another nibble.
By the time you have it down to a manageable size it will be 36" which is what WM advertises that the sawmill can handle.  I have loaded 42's a few times, but they were no fun.
WV Sawmiller
MM,
   I'm assuming he can still set that 4" first slab aside and resaw it later if its fairly uniform and worth the effort.
   Why do you have to turn 1/8 for the next nibble? Why not 1/4 and take another 4" which could also be resawed? I haven't tried trimming one down quite that big yet.
derhntr
WV,  if you rotate 90 degrees you exceed the cutting width of the guides. You still have a 40 inch tall log but now have close to 36 inches wide to cut with 25 inches between guides. It will not fit. And you have same problem if you rotate 180 you take another 4 in slab and cant is still 2 wide. Sorry I can not put in to words what I am trying to express.
You can only hope that the log is oblong or you may never make that first cut.   :-\
42" Sinker Cypress  &  Biggest log on LT-40? Thread
Sixacresand
Someone on the Forum advised us to take blade off to see if the blade guides will pass from end to end.  Takes time, big logs take a lot of extra time and effort.
terrifictimbersllc
It might, you have to try.  I believe I've loaded 5100 pounds before.  Turning that weight is harder than loading.
Delawhere Jack
Your in for a Doctorate level test of skills milling one that large, trust me......  ::)
I've started telling clients that 36" diam is a hard limit. Over that, split it with a chainsaw before I arrive.
Delawhere Jack
I often use my "end tong" and log clamp to help the loader by snugging the log toward the loader hinges.  Yes, it helps.
Chuck White
Welcome to the Forestry Forum, Scott Sawdust!
Your LT40 shouldn't have any issues lifting that log, I have a 1995 LT40 and I've loaded 38 inch diameter X 16 foot Hemlock logs with no issued.
As already suggested, you'll more than likely have to turn a little, whittle a little and turn again and so on until it's within your mills normal capabilities.
POSTON WIDEHEAD
I sawed a 39 inch Poplar log a couple of years ago. The biggest logs I've sawn.
Sawing Poplar is cheating a little... :D they're generally round.  :)
But before I did, I was a little unsure about how or if I could.
I called Magicman and got his advice and tips.
He helped a lot and I now saw a good many logs over 33 inches comfortably.  :)
Peter Drouin
Try it, If the mill will not load it, roll it away and rip in ½ then load ½.
A&P saw Mill LLC.
License NH softwood grader.
Czech_Made
Quote from: Delawhere Jack on May 26, 2016, 05:40:42 PM
I have seen log splitted with black powder,  more fun than the chainsaw  ;D
derhntr
I have split large oaks with black power ;D and it is fun. On the right log you can get a pretty smooth split. You have to spend a little prep time with the chain saw. I cut a 3-4 inch deep channel on both ends and same for length of log. Then bore holes with auger bit about half the depth of the log. Number of holes is dependent on log. Normally 3 holes for 8-10 footer.  One about 16 inches back from each end and one in middle. I will not say how much powder I use or what kind but it is not very much.
Been a long time since I have done this. I have one I need to do one day its a 42 incher that blew down last year. I just don't have the equipment to move the logs and ground is still wet where it lays. It is still propped up by linb and root ball.
paul case
Quote from: Peter Drouin on May 26, 2016, 08:07:19 PM
Nothing would be more disappointing than to get the thing loaded with some loader or other machine and then not be able to move it at all. Been there. Did that. Didn't end well but I won.
PC
pc
Scott Sawdust
Thanks to all for your input! I have usually opted to split these large ones rather that turning them, as you all said it is very time consuming. Also my cut quality really suffers when cutting full width boards 25-28". Hard to keep the cut from waving  up and down.
25"+ of unsupported blade is asking for much.  .055" blades would help and very well adjusted blade guides are a must.  You also had better have the correct sharp blade.
goose63
This one was to big for NDRanchers mill but with a little help form the Grandgerg we made it fit
goose
thank you to all the vets
Scott Sawdust
I am cutting all hardwoods, ash, cherry, walnut, oak, locust. Using .045" x 1 1/4 x 158", 4 deg hook angle. How tightly do you adjust your guides?
YellowHammer
Quote from: paul case on May 27, 2016, 09:31:15 AM
PC
That's pretty much what happened here.  Loaded it, fought with it, gave up on it, split it then chewed it up.  This is just one of those things, I had to try. ;D  The loader arms loaded it, but even moving to the side, lowering backstops, etc, it was just too wide to get a bite with the saw.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
