Price of a 6 cylinder liquid cooled Deutz?
Started by Trapper John, May 25, 2016, 03:29:46 PM
Trapper John
I have located a Deutz 6 cylinder liquid cooled engine (BF6M1013C) with clutch/PTO with 1800 hours.  Been inside all it's life.  What is this engine worth?
ladylake
Don't know but check the price of repair parts first.  Steve
paul case
I thought all duetz engines were air cooled?
PC
pc
Brad_S.
Is it truly a Deutz? The 4 cylinder liquid cooled Deutz that came on my mill was actually a rebranded Lombardini.
Ox
Quote from: paul case on May 26, 2016, 12:13:33 AM
Some were, some weren't.  Belarus and Same has some air and liquid cooled as well.  These are the only ones I'm sure of and I don't know enough to say any more.  Duetz is legendary for toughness and longevity.  Around here you can't even touch one unless you get a loan!
larrydown60
My cousin  just sold a tractor (deutz ) with mower for $2800.00 the electric clutch broke and he couldn't get a new clutch so he took a husqvarna electric clutch to a machine shop and had to modify the clutch 3 or 4 hundred dollars later he had a clutch that would work. The factory clutch was no longer available I don't know if this helps just my two cents
dgdrls
Hello Trapper John,
Not certain on price, I searched a bit online with little success
what do you plan to drive with it?
Dan
rjwoelk
Just bought a coop implement  tractor has the deutz  6 cylinder.  With a Schulte snowblower and 8 ft dozer blade. Payed 4500. Gets me pto ,hydraulics
Using as a power plant.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
