hellllllppppp!!!!!!!
Started by hopm, May 23, 2016, 08:14:18 PM
hopm
I have a small manual mill that was cutting close to perfect until last week. Tried to cut saturday and this afternoon and cannot get a straight cut. I have checked level to bunks and it is dead on. I have leveled guides. I have checked level on rails. I have changed blades. Nothing shows an issue except the cut. When I hit the end of the log the the blade is obviously under pressure and pops up when it clears the cut. There is a 3/8 to 1/2 inch variation in the cut.
The only change that has been made is a new drive belt. I can't convince myself the drive belt would have caused this. Any suggestions? Any place to start looking? I have exhausted my options and would greatly appreciate any assistance.
Tom the Sawyer
Double check the drive belt tension but the first thing I would do is replace the blade with a new, or re-sharpened, blade.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
hopm
I put a new blade on and had the same result.
Ljohnsaw
Was your blade speed consistent throughout the cut?  You mentioned a new drive belt - is it slipping?  How's your cutting speed - faster or slower than normal?  Is it just this log?  If you have another log to try, I'd do that.  What about flipping the log end-for-end?
John Sawicky
Cazzhrdwd
Are you sawing something different from last week? Different species or old logs can do that.
96 Woodmizer LT40Super  Woodmizer 5 head moulder
hopm
New drive belt is much tighter. No slip
Same logs
Speed seems consistent
Den-Den
A couple of questions:
Does the blade run on the drive belt?  If so the belt may have a different outer profile changing the blade alignment.
Did you move (purposely or accidentally) a wheel while changing the belt?
This type of problem is usually caused by alignment problems of some type.
hopm
Blade does ride on the drive belt
The belt I replaced was probably 8 or 9 years old and was worn much thinner than the new belt.
barbender
     What kind of mill do you have? That sounds like a tension issue. Also, check and make sure that the replacement belt has the same profile. If it's too narrow for your sheaves, the belt will slip even though it is tight. I experienced this with my Woodmizer- the triple belt on my mill had wore enough that the belt was bottoming out in the bottom of the sheave. I couldn't figure out why the belt seemed to be slipping when I had it tensioned to spec. I finally replaced it with a new belt and that took care of the problem.
Brad_bb
Did the new belt being a slightly different length since it's new and not stretched out, cause you to have reduced blade tension?
kelLOGg
The blades may be new but the set could still be off. The up-pointing teeth in the log could have less set than the down-pointing teeth; that would cause a dive which would cause the blade to pop up upon exit. Just my 2 cent idea.
Bob
Kbeitz
Make sure your throttle cable did not slip.
Love machine shop work
and Wood work shop work
And now a saw mill work
Cedarman
In trouble shooting blade problems, it is always good to keep a blade set back that you know is cutting well.
So when sawing problems develop, you can put a blade on you trust to saw well and see if that corrects the problem.
Hopm, once you get this problem worked out and you have a blade you trust, set it aside to help solve future problems.
sandsawmill14
the first thing i would do is kick the log off and try another one i have had that problem before more often in pine than anything else  :) if that fixes it put the log back on from the other end and try it but some logs just wont make good lumber :-\ i have seen lumber come off off circle mills that was 3/8 or more thick in the middle and the cant over an inch thin in the middle it is the same on the ends because the dogs wont let the ends move. if that doesnt fix it put on one of your old blades that was cutting right but was a taken of because it was dull if you saw real slow with the blade that was known good but dull it will saw like you are used to seeing when its time to change blades. its not as good as having a known good blade for testing but it does give you somewhere to start :) as others have suggested when you get it figured out put up the first new blade testing problems such as this and it will pay for itself many more times than just sawing till its dull ;) also check the log real good for small nails or something that could be easy to miss i similar problems one time when i hit a nail 4-5 inches deep in a log since i had already sawed 3-4 boards of that side i didnt think to look for metal till i ruined the 3rd blade smiley_dunce
hopm
Problem solved....it was a simple ID-10-T error.
What are the chances of 2 bad blades back to back......3rd blade cut like it's supposed to.
Of course it was good for me to build up all the frustration while changing belts blades pulling strings checking levels etc.....but seriously there is always a silver lining and in this case all the answers that rolled in on this forum was solid gold!!!
Thank you for your help!!
Kbeitz
kelLOGg
Quote from: hopm on May 24, 2016, 03:12:28 PM
Good for you. Can you explain the error? :P
Bob
Quote from: kelLOGg on May 25, 2016, 06:45:24 AM
Good for you. Can you explain the error? :P Bob
"(pronounced eye-dee-ten-tee) Technical support shorthand used to describe a common computer error caused by a user.  An id10t error is one that the user usually will not admit responsibility for."   :D
Ljohnsaw
Quote from: Magicman on May 25, 2016, 08:29:19 AM
:D Worked in the computer field for 35 years and never heard that one - MM, you are a wealth of information ;)
John Sawicky
dboyt
id10t... ID10T... I get it.  As in "of course it's plugged in.  What kind of idiot do you think... wait a minute... never mind."
sandsawmill14
 :D :D :D   glad you got it figured out :)
pineywoods
Thats a mis-print of the real definition...I D I O T   ;D
samandothers
PEBKAC issue.
Problem Exists Between Keys (board) And Chair.
