Large tulip poplars
Started by WV Sawmiller, May 20, 2016, 08:46:50 PM
WV Sawmiller
   I know lots of you guys cut and mill some really big trees but I got an order for 1600 bf of poplar. Most of the lumber is to be 12" wide so I needed some big logs. I was planning on cutting 4 trees but after cutting and bucking the first 2 trees into 8, 12 & 16 ft lengths per the order I measured them today and calculate using Int'l 1/4 scale I have over 2600 bf so far so I stopped cutting for the time being. I expect I will salvage a few hundred bf more out of the tops before I am done plus the normal overrun from using a thinner kerf. I also cut a small maple with a broken top which yielded a 17' log 12" id at the little end when clearing the path. It will give me 100 bf or more 4/4 boards I am sure.
   I have a man coming in Tuesday with 2 Belgian mules to drag my logs out. I am excited to try that and my wife is anxious to photograph the whole exercise. I'll try to post some good shots of that.
   These are much bigger trees than I usually cut. I have a few more up the holler to thin if this works with the mules as expected and I get orders for the wood. My problem before has been getting the logs down with my undersized support equipment.
   I am scared every time I cut these big (for me) trees. Nearly got my 4 wheeler with the last one I cut (Yeah - pretty obvious now I should have parked it further down the trail). It did put a bend in my Logrite (Sorry Tammy - I know I promised to take care of it when you sold it to me) when the second tree landed on it, a limb/top put a nice dent in my 4 wheeler basket at the same time and thought I was going to lose my Sthil 441 with the first one but fortunately it cleared it when it bounced off the stump.
   Anyway it amazed me to find that many bf in my trees. I have some bigger but some I'd have to split with chainssaw to fit on my mill.
Dave Shepard
We have a little tulip around here. I like sawing it, but don't get much if it. What is a Belgian mule?
WV Sawmiller
Quote from: Dave Shepard on May 21, 2016, 07:42:30 AM
Dave,
   Mama was a Belgian horse. Daddy was a donkey. Very big mules.
   Successful mating requires digging a pit for the mare to stand in or building a platform for the donkey to stand on. Sort of like crossing a dachshund and a Great Dane.
Upper
Stihl 661
Alaskan 36 CSM
36" guillotine splitter powered by a GMC V6
I like to build stuff
LT35HD Wood-Mizer
starmac
I would think a breeder using belgiam mares for mules would have a mammoth jack stud.
Don't worry, that donkey stallion thinks that he is.   8)
Upper
A Mammoth Jack is just a big donkey that likes a little junk in the trunk........... :-X
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
grouch
When do we get pictures? I want to see the trees, the logs, the mules at work, and sawdust.
Pics or it didn't happen. :)
Find something to do that interests you.
WV Sawmiller
Grouch,
   As I mentioned in original post the guy comes with his mules on Tuesday so hopefully I can post some decent pix that evening.
plowboyswr
Just an ole farm boy takin one day at a time.
Steve
rjwoelk
My dad worked for a rancher north of Swift current sask. They raised mules, they used the ramp and a box for the mare. Dad said that that stud donkey would come at at a dead run when they let him out. ;D
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
WV Sawmiller
rj,
   Thanks for your verification of the process. I was crushed because I think upper had some doubts about my credibility for a bit there. (As you can tell I am real sensitive like that. :D :D)
   My mule raising neighbors have just taken a backhoe and dug out a quick narrow pit 2-3 ft deep for the mare with the same results.
Upper
Sorry WV,my first post was all that was left of an edit,thats all.But I will teel you I was a world champion Mule Packer back in 1978,Bishop Ca...Had a mammoth Jack that I bred mares with.
Stihl 661
Alaskan 36 CSM
LT35HD Wood-Mizer
WV Sawmiller
Upper,
   No offense taken. I have a 600 lb mule (likely a pony mule) I bought my wife for our 20 year wedding anniversary present. We also have a half Belgian/half walking horse we got several years later. I never knew mules were so social till we got the horse. The mule goes crazy if separated from the horse now. The horse acts like he couldn't care less. The mule is smarter than the horse.
   I have seen a few big jacks but they are not common around here.
   I am excited to watch this teamster logging my place with his mules. These logs look awful big to me for an animal to tow. I've heard old timers say well trained horse/mules worked pretty much alone. Guy in the woods would hook them up and send them alone. Helper at the landing would unhook, put the chains on the hames and send them back and the animals made the trek all day long by themselves. Even had a Gee hook that would do a quick disconnect if they yelled Gee and the animal stepped to the right. On the steep slopes if the log started sliding and the animal felt slack they would automatically step to the right to keep from getting a broken leg or such.
Ljohnsaw
John Sawicky
Weekend_Sawyer
We finished the interior of our cabin with tulip poplar, I like it a lot!
Jon
Imagine, Me a Tree Farmer.
