More Pics of my sawmill build
Started by larrydown60, May 17, 2016, 11:39:02 PM
gww
To ljhonsaws point.  I had my mill running at about 9000 fpm and was going through guide bearings.  The saw did cut but I slowed it down and do believe it made it better.  My blade might be lasting a bit longer also.  Nice mill.  I am almost dissapointed that you are putting hydrolics on over the winter.  I will have a hard time waiting that long to see you cut your first board, always and exciting thing for me.
Good luck
gww
larrydown60
ljohnsaw Thank you you for the info I will switch the pulleys around tomorrow, nice catch Kbeitz  you guys just saved me some headaches later on thanks again
Ljohnsaw
Larry,
That is assuming your engine speed is at or about 3,400 rpm.  You could throttle back but then you are not in the right part of the engine's power curve.  Best to have the right gearing!  Good luck on your homemade bearing guides.  Mine didn't last (went through 3 sets I believe) and I went the Cook's route and have been very happy with them.
John Sawicky
larrydown60
gww, I will have it up and sawing very soon installing the lift system tomorrow and guides also received all the machined parts Saturday. I have had bronchitis for a week and half now. just can't get my energy going, new meds hopefully it will clear up soon. just plugging along now. I won't make everyone wait till spring to see this sawing. LOL. I will be gathering everything I need over the winter to put the hydraulics on come spring
larrydown60
Ljohnsaw I do believe the motor is 3500 rpm I will post pics of the guides tomorrow just need to get some bolts to finish them up. I hope they work
4x4American
I am excited to see this thing sawing.  What are you gonna saw first?
Boy, back in my day..
larrydown60
4x4American all that I have to saw up right now is some good sized Locust logs. A friend had a tree taken down the other day and there is some good lumber lying there. There is a couple of 36" x 8' and bunch of 30"x 6' pieces and lots of short pieces of 4' lengths and some good looking crotch pieces. Going to borrow a friends trailer that has grapple loader on it to pick these logs up. I am now going to have to either upgrade my truck or add the 2500 suspension to my truck so I can haul the weight around. It never ends LOL
larrydown60
Ok all my my blade guides are all welded up and ready to weld to to the saw here is a few pics
4x4American
Looking good.
Cook's just posted a video on blade speed, thought you might like to see it:
https://www.youtube.com/watch?v=6yCZ9YMs0jA
larrydown60
Thanks 4x4american video is a good bit of info thanks again
larrydown60
Just a few pics of the acme threaded rod setup lower cup with bearing and an a adapter for the acme rod and the the acme rod lift tube battery ran out before I could get more pics, tomorrow is another day
4x4American
Now how do you know that tomorrow is another day??   :D
'Cause it ain't yesterday.   ;D   :D
larrydown60
BECause only the good die young and I am to miserable,stubborn and rotten to die. So I know I am here for a lot longer. 8)
larrydown60
A few more pics of the acme rod set up and lift. Stripped the saw mill down to paint everything one last time
larrydown60
Sorry it's been awhile since I posted anything. Made some changes to the saw mill added 2 more post to the head added the water jug holder and gas tank holder and battery box installed and put the final coat of paint on everything. going to assemble everything tomorrow. Finally got the winch for the lift and waiting on machine shop to modify it. Hopefully get the blades ordered tomorrow or Tuesday Everything is finally coming together hope to have it running by next weekend
fishfighter
Looking great. Bet you can't wait to bust up that nice paint job. ;D
Ox
Yeah, don't scratch the paint now!  Looks great.  Big too!  Hopefully it performs as good as you're hoping it will.
Gearbox
I may be wrong on that engine . On my 27 HP water cooled Briggs it has a torque curve that is flat from 2000 RPM on up with all most no rise to 3600 . So you should be able to throttle and cut any where above 2000 RPM .
larrydown60
Not worried about the paint I just want to see this thing cut some logs. Plus I have more paint to use up LOL
Picky2016
Nice job Larry, keep up, you'll be cutting in no time!
larrydown60
A little progress today got everything ready for the wiring tomorrow and hopefully running if everything goes according to my plan here is a couple of pics of my homemade guide wheels installed. Still waiting on machine shop to finish the winch modification.
Ox
I still can't get over how rugged everything seems to be.  I predict zero flex.
Kbeitz
I my my mill very rugged. I got flex from the roller bearings that the carriage rode on.
This was my fix... Slack adjuster.
Love machine shop work
and Wood work shop work
And now a saw mill work
larrydown60
Kbeitz On the drive side I only have 20 thousands spacing in my saw box that goes up and down, on the idle side there is 1/4 clearance on saw box 1/8 on each side of the 3x3 tube that was figured in for flex so the blade won't brake it gives it a little flex Have not run it yet maybe tomorrow then I still have to order some blades more pics tomorrow
