Need Practice!! HA HA
Started by Kauff44, May 07, 2016, 08:03:48 AM
Kauff44
Finally fired up my bellsaw for the first time ever!!! All excited, I ran my first log and well let's just say it's hard to use rough sawed 3/4" boards. Ha ha ha. Man I have to remember that 1/4" saw blade. This is definitely going to take some practice. Happy to say that every thing seems to be working well just need to do a little work on the sawyer!! Ha ha. Practicing on a hand full of balsam log before I start on my ash logs I'm using for flooring. Want to make sure I got a handle on it so I don't ruin a good piece of wood. It's amazing to see a knotted rough log turn into a beautiful piece of straight lumber. Just though I'd share a laugh. Happy sawing, Be safe, and God bless!!
Thanks, God Bless
Chuck White
Just a little fine tuning with the sawyer and it'll be great!
Congratulations and happy sawing!
Bricklayer51
Went past your place last week saw some logs in two places you got a nice place there.
Bruno of NH
4x4American
Boy, back in my day..
Dad2FourWI
You are right across the water from us.....
We are finally having some success and a LOT of that is due to the people in this forum!!!!!! A great bunch of experienced sawyers!!!
Share your successes (and failures...)!!!!!
Have fun opening up each log!,
-Dad2FourWI
LT-40, LT-10, EG-50, Bobcat T750 CTL, Ford 1910 tractor, tree farmer
svart ole
Ah, the tell tail signs of a sawmill addict in the making. And he is using one of those evil round saws! Next thing you know it will be edgers and planers and jointers, Oh my!
Keep at it. It wont take long before you can look at the rule on the setworks and know what you have to pull. You will get real good about thinking in fractions of a inch. All the belsaw mills I have seen ever had a very fancy setworks so there was never a mechanical stop on the setworks so you could just "pull a inch" (1 1/8" + saw kerf).
There has been many Mbf of lumber sawed on those little belsaw mills over the years. Have fun and just remember sawmills are inherently dangerous and the most effective safety equipment you have is in your head. Think before you act.
My wife said I collect junk, I told her I am a amateur industrial archaeologist just trying to save valuable artifacts.
Kauff44
OK some people post the picture right on there reply. all i can do is the path. am i doing something wrong?
Thanks, God Bless
Quote from: Kauff44 on May 10, 2016, 06:18:48 PM
You are 90% there
Go to your gallery and find the picture you want to use.
Then on the page below it will be the text "To use the above photo in a Forestry Forum post" and a box with this in it.
[img]https://forestryforum.com/gallery/albums/userpics/42299/Mill1.jpg[/img]
Copy that code into your post, and you get
pineywoods
copy and paste can be a bit clumsy on some phones. Actually, you don't have to. Keep scrolling down under the pic and you will find a button that says, "click here to insert in a post" Click on it and the link to the pic is magicly inserted in your post...
But the actual picture is not visible in the post, only the code.  Click Preview and scroll up to see how your reply will actually look.  You can now scroll back down and make any changes that you want to the then click Post.  The Modify button is there so that you can still make corrections after the post is made.
Quote from: pineywoods on May 10, 2016, 08:09:41 PM
True, but we have found that doesn't work for every browser / OS / security settings combination. If it works on your machine, great. The copy and paste will work on ANY machine, although I agree it's fiddly on a phone.
Kauff44
Well hope this worked. this is my brother on the Mill. im on the back side of him trying to explain how the scale works. its like the Blind leading the Blind i guess HA HA. Getting much better at it now still a very long ways to go, but at least im getting straight 2" and 1" boards now.  8)
Thanks, God Bless
Kauff44
Here are a few more pics
Some of boards i've cut so far
Skid way loaded
 [img]https://forestryforum.com/gallery/albums/userpics/42299/5.jpg?easyrotate_cache=1463071111[/im
Lawn mower runs the blower
Thanks, God Bless
Weekend_Sawyer
Glad you got it!
Nice mill setup. Thanks for sharing.
Jon
Imagine, Me a Tree Farmer.
svart ole
Nice clean setup. That cement slab is going to make clean up nice. Now all you need is a roof for the rainy days and the short winters you get down south.  ;D The one thing that made me twitch a bit was the power plant sitting on the blocking. First thought was I hope it is bolted to the blocking and the second was that block under the front of the engine sitting on the ground looks a bit too tippy for me. I would think two timbers turned 90 degrees would be more stable. Wet weather and in the spring things get soft.
Looks to me like you are doing well. Take your time learning the feel of things and the speed will pick up. If anyone gives you a hard time about saw kerf, just smile and remember more good lumber at days end is worth more than a few low grade boards you hope you may get with less kerf.  ;)
