Got this in a barter deal for some Web work.
Started by Jeff, April 28, 2016, 08:37:21 AM
isawlogs
 8)    Floor space in da Barn,  :)  Love them old rides.  8)
   Marcel
Gearbox
Show us a side shot so we can tell if is a 8N 2N or 9N . Looks  nice
Bricklayer51
Green acres is the place to be farm liven is the life for me. Great score.
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
WmFritz
I love old tractors. From the SN, you can find out the date it was manufactured. Oakley has a big antique tractor show every summer, not far from my house. I found a shop manual for my '59 there.
Nice score.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
I actually got TWO tractors and 6 implements.  A trip bucket, a flail mower, a cultivator, a plow, a disc and a back blade. The back blade is too big for the tractors. I can only get it about 4 inches off the ground. The disc is in rough shape, and the drag needs work too.  Both tractors run really nice, but the one has a radiator leak.   I'll have to take a few more pictures.
Were would I find the serial numbers?
Dave Shepard
Remle
   "Were would I find the serial numbers?"
On the engine block, left-hand side, just behind oil filter.
Once you have the serial look here for the year.
http://www.tractordata.com/farm-tractors/tractor-brands/ford/ford-tractors.html
Here are some more photos of the tractor Tammy is on.
pineywoods
I see the old 6 volt generator has been replaced with an alternator..good move. 12 volt electrics ?  You may find that the brakes ain't much. Problem is not brakes, the axle seals leak rear end grease on the brake shoes...That little gadget on the pto shaft is an over-run clutch. very useful when you hook up a bush hog..
Good score, those old tractors have their limitations, but run forever...
And this is the other tractor, the one with the radiator issue. I was told they thought this one was the newer tractor.
OneWithWood
Good to have two tractors.  One for down home and one for the UP.
One With Wood
yukon cornelius
serial number is on the engine block. in the engine close up pic you can see a rectangle "plate" which is a milled flat area with serial stamped into it. You can identify between 9n and 8n by wheel bolt pattern both of yours have 8n bolt pattern. 9ns have a really wide bolt pattern.
Nice score!
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
yukon cornelius
also, the serial number plate area is on the starter side just above the starter.
yukon cornelius
one more thing I can add, it appears the distributor on rustier one is on the side and the cleaner one is a front distributor. the side dist. is the newer of the two.
Here are the implements we were able to get on with the tractors. Still have to haul the drag and disc.
Ljohnsaw
Nice score!  They look like they have pretty good rubber, too.  Hmm, you are gonna need a bigger barn, though. :D  There is a guy here that picks up old tractors from Nevada and such, gives them a Rustoleum rebuild and sells them for $2-3000 without implements.
John Sawicky
Gearbox
Both are 8 N .The one with the tack is the newer one . It should lift that back blade easy . Dip stick is on the right under the seat by foot board . takes 90Wt . If it is milkey oil replace the oil and most times the water gets in past the shifter boot . Enough for now
WV Sawmiller
Jeff,
   Congratulations. I love barter deals.
FF Members,
   Can you guess which of the 2 tractors shown belongs to Tammy and which one belongs to Jeff?
Quote from: Gearbox on April 28, 2016, 12:25:41 PM
It lifts it, it simply won't lift it high enough. The thing is really big. Wide and tall. With the 3 point all the way up, the blade is only about 3 inches off the ground.
WH_Conley
Cheapest place I have found to overhaul a disc. I just got 14 blades for a wheel disc delivered for $156.00.
http://www.agrisupply.com/
Bill
square1
Quote from: Jeff on April 28, 2016, 02:25:24 PM
Looks like you have a couple few inches of top link left to raise it a little higher.
They look good. The rusty one looks like mine '54. Always was outside until about 2000. I have it under cover now.
Gearbox
Jeff old farmer trick heaping tablespoon of black pepper or ginger will stop that leak while you watch .  Let it idle and put it in . almost all farm clubs have someone with it in there pickup .
