CBN Wheels
Started by Peter Drouin, April 27, 2016, 08:43:13 PM
Peter Drouin
I'm getting 600 to 676 blades sharpen with one wheel counting going around one time. I do grind heavy and go around 2 times sometimes. So is that a good number for the life of the CBN wheel, or is someone out there getting more blades done?
A&P saw Mill LLC.
License NH softwood grader.
Cedarman
What are the indications that your CBN wheel is worn out?
Peter Drouin
It will not sharpen the blade. :D :D Do you have a CBN? I was hoping for some numbers, how many blades it can do.
A&P saw Mill LLC.
Cedarman
I normally just go around once unless blade has some damage and needs several trips.  I haven't kept track of number of sharpenings.  I would say I am getting close to 1000 trips.  Still have 200 to get to your level.
NMFP
On my machines, processing an average of 500 bands a month, I am getting around 1200-1300 sharpening's on one wheel.  I also use soluble oil B for the coolant with a cleaning additive.
What machine are you running?  I do not have any experience with the 8" machines but I would guess they would last a little longer as the surface area is greater.
xlogger
Cedarman, what angle do you sharpen your blades at? I saw mostly cedar also and trying different angles and sets now.
pineywoods
Little early to tell. I adapted a rixsaw 10 deg wheel to my old wm drag sharpener. Been 3 or 4 months use, but had to re-profile a bunch of junk blades. Lots of grinding. Some areas of the wheel are showing some wear, especially the face to gullet transition area. I got a note from rixsaw offering to re-coat my wheel if I ever wear the cbn coating off. Anybody done that ?
Percy
Quote from: Peter Drouin on April 27, 2016, 08:43:13 PM
I havent kept track of the numbers like you but Gary at Salmon Arm Wood-mizer told me Id see the coating gone in spots when they wear out. I cant remember for sure when I changed it last but Im sure its been 3 years. For lube, I use a good quality 32 rating hydraulic oil.
Cedarman
xlogger, I use 10 degree blades.  We have tried other angles , but didn't notice much difference.  Saws frozen ok.  We have lots of blades in circulation and I would hate to keep track of other angles.  Would have to change the CBN wheel if we went to other angles.
Peter Drouin
Quote from: NMFP on April 29, 2016, 07:50:50 AM
I have a WM set up. That's a lot of blades you do, You must be real light on the grind.
You must go around the blade 3,4, times. Customsawer says he goes around 5 times on a blade. Maybe he will tell us how well he does with a wheel.
A&P saw Mill LLC.
customsawyer
I don't try to keep a count on the blades per stone. When I first started I was going to but with the number of blades I go through I lost count. Now I just change the stone once it's worn. I figure it as a consumable part and let it go at that. If I had to guess I would say in the 500-700 range. I only do the 5 passes on the first sharpening of a blade when using the WM stones. I now use a rixsaw wheel and change the profile to a 4/39 and I can clean up the profile in 3 passes. Keep in mind that the reason I take so many passes is due to what I am cutting and how rounded the teeth corner gets.
www.thecustomsawyer.com
Peter Drouin
Do you use 4° all the time?
A&P saw Mill LLC.
customsawyer
Not when they are new but once I sharpen then yes. Now the cooks is set up at 7 but I'm considering changing it to 4 also.
elk42
Customsawyer
  On my cooks Cat claw  I let it down on the clamp screw and it was 4 1/2 ° then I used a file to bring it down to 4°.
Machinist Retired, Lt15 WM 25 HP, Stihl 044, Stihl 311, Kubota M2900w/FEL, KUBOTA L4800 w/FEL,
Lincoln Ranger 10,000, stihl 034,
Peter Drouin
So your cutting 40' matts with a 4° blade?
A&P saw Mill LLC.
customsawyer
NMFP
I keep track of the number of bands I do for cost accounting and for costing jobs.  I have had wheels last only 100 bands and then some last 1200-1300 bands.  It all depends on how bad the bands are and if I hit something that's embedded in the steel I cant see when cleaning.
I have numerous sources for wheels as I sharpen any brand out there and have had a lot of wheels made over the years for specific brands of bands.  I just had a wheel made this winter that is designed to sharpen a really deep and aggressive carbide band.  That wheel was just a little over 600$ for a wheel.  Next time, it will be less but not knowing how many bands I will do for the customer, its a real gamble.
My experience is you will know when the wheel needs replaced or recoated and a lot depends on condition of bands that come to you and how many passes it takes to clean up the bands to a square tooth tip.
JustinW_NZ
Quote from: pineywoods on April 29, 2016, 09:21:23 AM
No, didn't know they could recoat them.
Keen to know myself!
And otherwise I get several hundred sharpens to over 1000 perhaps?
I do say three light passes around the band normally?
I run a stock of about 80 bands.
7deg turbos and 10deg (all WM bands/gear with rixsaw CBN wheel)
I did find my machine had gone out of alignment and chewed a spot on the last wheel hard
didn't last as long and now I'm paying for it again as I 'reset' the profile back to the right angle.
I use a locally made tool sharpening oil to keep things clean and cool.
Cheers
Justin
Gear I run;
Peter Drouin
Recoat, guess I'll stop throwing them out. :D
A&P saw Mill LLC.
Stephen1
Hi guys, I am keeping my eye on this post. I hit lots of nails and would love to convert my WM drag sharpener to CBM. I see a few have done it. Is there a good link on how to convert it.
pineywoods
To upgrade to a cbn wheel, you will definitely need a different cam. Good idea to upgrade the motor also. I did mine a couple of months ago and there is a post with pictures in the sawmill section. I made my own cam and mounted a 1/3 hp 110 volt motor. I use water plus machine shop cutting oil for coolant. You may need to upgrade coolant flow also..
dustyhat
Do you have a link to that spot ( pineywoods ) ? interested myself.
shakebone
Dont know exact count of blades but when i started using 1/2 deseil and 1/2 cutting oil it really increased the life of the wheel .
Lt40 super desiel , LT 35 hyd , New Holland ls 180 , Case 75xt ,
So many logs so little time.
Peter Drouin
Quote from: shakebone on May 02, 2016, 02:43:29 PM
I"ll try that, thanks
A&P saw Mill LLC.
pineywoods
